196 Rebuilds
1973 196 rebuild question
24
25
26
27
44
Topic: 1973 196 rebuild question (Read 24507 times)
September 05, 2024, 01:21:29 PM
Reply #360
Re: 1973 196 rebuild question
Reply #360 on:
September 05, 2024, 01:21:29 PM »
Rick, I’ve been thinking about the water pooling thing in the stern where my gutter trough is and am thinking some sort of slope like a portion of a pyramid only longer and flatter. I am going to cross that bridge when I put the deck down. Got my tank today looks great. $1800 though, ouch. There goes my budget. The guy who did it is in Elberta AL. I would be glad to share his info if anyone in the mobile Al to Pensacola Fl area is looking.
September 05, 2024, 05:32:51 PM
Reply #361
Reply #361 on:
September 05, 2024, 05:32:51 PM »
I hope you understood the drawing I made to show how to slope a portion of the deck on each side. a 1/4" side to trough slope is enough to drain the deck.
If you received plans/drawings for your tank you can post that and the builders info in this thread
https://classicaquasport.com/smf/index.php?topic=11420.0
September 09, 2024, 07:28:35 PM
Reply #362
Reply #362 on:
September 09, 2024, 07:28:35 PM »
Got my tank. I did understand what you were talking about with the corner slope. Thank you for the Input, very helpful
September 10, 2024, 12:27:07 PM
Reply #363
Reply #363 on:
September 10, 2024, 12:27:07 PM »
Ok, I'm confused about how your tank was made. What are we looking at in the pic of the tank? I see a sending unit and 2 other things - 1 I assume is a fill pipe and the other? Maybe the vent? or the pipe connection to the engine? Maybe what I think I am seeing as a fill pipe is actually the outbound pipe to the engine?
If we're looking at a fill tube, is the fill tube on the correct side? Usually the fill hose and vent tube are on the starboard side. Reason I ask is I see a lot of pictures lately that seem to be flipped 180 degrees vertically, which makes for example, people you know that are right-handed (watch on the left arm) now have it on the right. I am not sure if it is a camera thing or a mode that pics can be taken (like regular or selfie). So please enlighten me - is the pic flipped or are you running the plumbing from the port side?
Trust me I have not been drinking
September 10, 2024, 10:57:56 PM
Reply #364
Reply #364 on:
September 10, 2024, 10:57:56 PM »
Drinking or not, you are seeing it correctly. It is the fill and the vent. The fabricator zip tied some fabric over the openings to keep dirt dobbers and debris out of it so it looks a little weird. The guy built it based on pictures and measurements I sent him. They are located where I wanted them but the angle of the fill is the wrong direction. I may be running them to the port side. It's just one more thing to do.
Laminated some tonight on port stringer.
September 11, 2024, 05:23:24 AM
Reply #365
Reply #365 on:
September 11, 2024, 05:23:24 AM »
Ok, so I wasn't seeing things. Going out the port side is not the end of the world. I have mine going out the port side.
Is your sending unit right there too? If so, do you know what kind of unit they installed? Is it an offset float or one that is directly below the unit? Also, where is the output to the motor? Out of our sight, on the other end of the tank?
September 12, 2024, 08:49:48 AM
Reply #366
Reply #366 on:
September 12, 2024, 08:49:48 AM »
Sending unit is out of picture at stern of tank. Adding some storage under the leaning post seat. Used the corner of the old fuel tank. Will need to make a side but will do that this w÷kend. Laminated some more of Port stringer
September 12, 2024, 08:51:22 AM
Reply #367
Reply #367 on:
September 12, 2024, 08:51:22 AM »
Not sending unit. pickup is out of sight at what will be the stern of tank
September 13, 2024, 08:37:03 AM
Reply #368
Reply #368 on:
September 13, 2024, 08:37:03 AM »
To your other question, I do know what type of sending unit was installed.
September 14, 2024, 05:43:20 AM
Reply #369
Reply #369 on:
September 14, 2024, 05:43:20 AM »
Reason I asked it that with the sending unit in the bow end you won't get a good read on the amount of fuel, especially when cruising. I see you cut open the old tank, what kind of float did the original have?
September 14, 2024, 09:47:14 AM
Reply #370
Reply #370 on:
September 14, 2024, 09:47:14 AM »
It had the toilet bowl type with the float on an arm. Finished the leaning post storage and glossing the "Coosa risers" on top of the stringers. Baseball bat solid. I had one section of glass I was unhappy with but not enough to grind out. I found it is near impossible to grind glass off Coosa without damaging the coosa.
September 16, 2024, 09:07:46 AM
Reply #371
Reply #371 on:
September 16, 2024, 09:07:46 AM »
This tool is helpful for angels and it was cheap. Get one if you don't have one
Tank fits. Should I support it from the bottom? Currently it has a point of contact on each side mid tank and the back corners appear to touch the hull. I was thinking something like below in each corner or a tube down the center. I have some solid rubber mats I was going to incorporate.
September 16, 2024, 09:10:01 AM
Reply #372
Reply #372 on:
September 16, 2024, 09:10:01 AM »
Tube or build piers out of Coosa blocks and rubber mats
September 16, 2024, 01:24:48 PM
Reply #373
Reply #373 on:
September 16, 2024, 01:24:48 PM »
I would use 3 tubes across to spread the weight across the width. They should be beefier that what you show, maybe 4 layers of 1708. One or two of the layers can be what you use to wrap and attach to the hull. If you are going to use short ones like shown, I would use 4 or 5 rows deep. The height of them will be different as you move forward and aft. You want a little angle toward the aft to keep the fuel to the aft.
September 18, 2024, 07:35:33 PM
Reply #374
Reply #374 on:
September 18, 2024, 07:35:33 PM »
I talked to the fabricator of the tank and he recommended the tube method or the glassed in pier at each corner of the tank method. I felt my skill set lent to the pier method. Here is my stab at the front piers.
24
25
26
27
44
196 Rebuilds
