196 Rebuilds
1973 196 rebuild question
28
29
30
31
43
Topic: 1973 196 rebuild question (Read 23813 times)
November 05, 2024, 04:39:11 PM
Reply #420
Re: 1973 196 rebuild question
Reply #420 on:
November 05, 2024, 04:39:11 PM »
Glassed in the rear support knees
November 06, 2024, 05:27:23 PM
Reply #421
Reply #421 on:
November 06, 2024, 05:27:23 PM »
Cut out the honeycomb. Makes me think of sugar smacks frog.
November 06, 2024, 05:35:12 PM
Reply #422
Reply #422 on:
November 06, 2024, 05:35:12 PM »
I'm thinking a 10 by 30 inch hatch on port side. Been looking at all yall's threads. Very helpful
November 08, 2024, 07:27:55 AM
Reply #423
Reply #423 on:
November 08, 2024, 07:27:55 AM »
First stab at hatch. Layers: Matt, 1708, 1708, 1708 scraps in all the corners
November 08, 2024, 01:24:35 PM
Reply #424
Reply #424 on:
November 08, 2024, 01:24:35 PM »
Looks good. Have to figure out how to drain the gutters.
November 08, 2024, 03:38:21 PM
Reply #425
Reply #425 on:
November 08, 2024, 03:38:21 PM »
Thought I would run the tube to the area in the bilge right next to bilge pump or perhaps to the deck gutter (probably not that). Having used the plastic instead of melamine as a base, it's pretty rough. Can I simply put a layer of Matt on it and grind/sand appropriately? Also, I bought a piece of melamine to make the hatch, what if anything can be used as a releasing agent substitute. I don't really know what releasing agent is and suspect it's not available here anyway. Can I use Vaseline or Pam or something like that. Do I even need to use it? I'm not laying gelcoat first on the melamine.
November 08, 2024, 03:43:39 PM
Reply #426
Reply #426 on:
November 08, 2024, 03:43:39 PM »
Another question, obviously the deck will have have a hole cut in it to drop the gutter system in to. Do I laminate first then glue/lam the gutter on top of glass or drop gutter in then laminate over it? Seems the first way would be better and easier.
November 09, 2024, 05:30:18 AM
Reply #427
Reply #427 on:
November 09, 2024, 05:30:18 AM »
Yes, you can add mat to give you a sandable surface or even a 6oz cloth.
When doing a small project you can apply clear packing tape on the melamine as a release agent.
November 09, 2024, 07:48:10 PM
Reply #428
Reply #428 on:
November 09, 2024, 07:48:10 PM »
I added the mat and I think that will clean it up. I ended up not using any releasing agent and it popped off the melamine no problem. I did use the packing tape in the angle aluminum and it also worked great. Here some more pics of the hatch project. No particular order.
Also, still working on anchor locker
November 11, 2024, 07:25:08 PM
Reply #429
Reply #429 on:
November 11, 2024, 07:25:08 PM »
2 layers 1708. Hatch will obviously drop into hole.
November 11, 2024, 07:28:42 PM
Reply #430
Reply #430 on:
November 11, 2024, 07:28:42 PM »
I know I didn't great contact on my hatch. I forgot to put a weight on it. I'm going to let it ride until it falls apart. I bet it doesnt.
November 11, 2024, 07:35:55 PM
Reply #431
Reply #431 on:
November 11, 2024, 07:35:55 PM »
B9ught a 9 pound Danforth like anchor at bass pro. It will barely fit in the locker but it will fit. Hope I can accomplish this project.
November 12, 2024, 07:26:40 PM
Reply #432
Reply #432 on:
November 12, 2024, 07:26:40 PM »
Cut the end off a brass fuel nipple and ground down . Thinking about making it a hatch gutter drain. Will 5200 it down.
November 12, 2024, 07:28:40 PM
Reply #433
Reply #433 on:
November 12, 2024, 07:28:40 PM »
Glassed the other side of the deck tonight. 2 layers 1708.
November 13, 2024, 06:18:17 PM
Reply #434
Reply #434 on:
November 13, 2024, 06:18:17 PM »
Took another stab at mocking up the anchor locker.
28
29
30
31
43
196 Rebuilds
