Aquasport Discussion
finally on the water!
Topic: finally on the water! (Read 1848 times)
May 05, 2009, 01:41:19 PM
Read 1848 times
May 05, 2009, 01:41:19 PM »
finally got some pics of my osprey on the water!
it does feel a bit under powered with the 112...
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
1989 Fountain 12-meter
SOLD
1992 Talon F-20
SOLD
May 05, 2009, 02:37:34 PM
MarshMarlowe196
Re: finally on the water!
May 05, 2009, 02:37:34 PM »
Nice! Make sure you post those on the 19-6 thread.
What kind of performance did you get w/ the 112hp? These boats aren't very fast as it is...
Key West 1720 / Yam C90
Sold: 1973 Aquasport 19-6
May 05, 2009, 02:59:03 PM
May 05, 2009, 02:59:03 PM »
SWEET!
May 05, 2009, 03:27:55 PM
May 05, 2009, 03:27:55 PM »
it topped around 28 mph with 2 guys, 8 gal. of gas, some trim, and on a 1 ft chop... takes a good bit of time to get up on a plane. deff gonna start looking into a 150 later this year
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
May 05, 2009, 04:06:47 PM
MarshMarlowe196
May 05, 2009, 04:06:47 PM »
Hmmm... I was going faster than that w/ much more gas and fat guys in the boat with a 90HP. (33mph WOT on the GPS)
Do you know what pitch prop you're running? Kind of confusing, because if you're taking a long time to get on plane, you'd think your pitch would be higher, but then your Top End should be higher than 28mph. Do you know for sure that your engine is running right?
I would say, if your engine is running right, and your prop pitch is right, you should top out around 35mph w/ that 112hp. A 150hp would probably only get you up to around 45mph WOT. ( I run right at 42.2 mph GPS w/ the 140hp w/ a 21" prop @ 6000RPM)
If I could change anything about these 19-6's, it would be a planing chime that ran the length of the hull all the way to the stern instead of one that stops just after the prow (which is completely useless). There's just so much hull in the water when you get up and run, and all that drag makes for a slow boat.
May 05, 2009, 04:32:03 PM
May 05, 2009, 04:32:03 PM »
gps showed 28.8... but i dont completely believe it... ill try tomorrow with my dads hand-held and see what the numbers are... i think its running around 32, it does feel
slightly
faster than our AJ that runs 29.9 on gps... prop is 13-1/2x17 and runs right at 5300 rpm, i believe the specs are 5200-5600 rpm
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
May 05, 2009, 06:35:47 PM
MarshMarlowe196
May 05, 2009, 06:35:47 PM »
Yea... it probably feels slightly faster because its a smaller boat. It's hard to fool a GPS, they all talk to the same satellites :) .
With a 17" prop, you should have no trouble popping out of the water w/ that motor. My dad used to sell these boats when they were new (19-6's and 200 Ospreys w/ 112 "special") and he's telling me that you should be doing 36-38mph w/ that setup.
Probably something wrong w/ your motor... :(
May 05, 2009, 07:47:59 PM
May 05, 2009, 07:47:59 PM »
im still not trusting that gps, it says im only going 5mph when im half way up on plane, and looses signal every minute. i
could
be doing 35 mph, i guess it just seems slow cuz ive been on my buddies flats and bay boats that runs 65 WOT more times this year than my own boats lol.
what mounting height where most of them at? mine is lowest it can go... im thinking about raising it up a hole or 2
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
May 06, 2009, 12:42:42 AM
Rigging Master
May 06, 2009, 12:42:42 AM »
Try second hole down, maybe third. The key is to have the cav plate at the water's surface while on plane.
As Bad... said, the prop is equally important.
Beautiful boat! Built more than my fair share. 150? Hey, I worked on an old Mako 17 in Tarpon that ran a 150. Your Osprey will handle it quite nicely!
May 06, 2009, 08:02:03 AM
May 06, 2009, 08:02:03 AM »
the cav-plate is almost parallel with the keel right now, almost every o/b i see at my work is at least an inch above the keel. im gonna take it out later today and play with the settings and what not
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
May 06, 2009, 01:28:57 PM
MarshMarlowe196
May 06, 2009, 01:28:57 PM »
SeaBob! Good to have you back. I thought you'd forgotten about us...
I hear you guys are back to building boats?
May 06, 2009, 03:46:54 PM
May 06, 2009, 03:46:54 PM »
well i got it out on the water today and reached 27.5 knots on my hand-held gps, so about 31.6 mph... i raised the o/b 1 hole and it seems to help with the planing, i dont get as much bow rise as i did before.
i did catch a nice size flounder though, first one ive ever caught! lol
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
SOLD
1992 Talon F-20
SOLD
May 06, 2009, 07:11:04 PM
flkeysaqua
May 06, 2009, 07:11:04 PM »
Like everyone one else has said nice looking boat. Just to add to bad's statement I have a 1988 140 on my 19-6 and after stripping all the bottom paint off and going with easypoxy from pettit my boat runs 42 or 43 with a good head wind
73 19-6 w/140 Evinrude
May 06, 2009, 07:38:34 PM
May 06, 2009, 07:38:34 PM »
Quote from: "flkeysaqua"
...my boat runs 42 or 43 with a good head wind
You mean "tail wind"?
May 07, 2009, 12:31:20 AM
Rigging Master
May 07, 2009, 12:31:20 AM »
Jessie,
Not yet. We've got orders (commercial included), but financing is quite a different ballgame than the pre-meltdown days. They actually want companies to be ACCOUNTABLE for their performance! Imagine that!
