No I mean head wind (helps push the bow up a little bit more) less boat in the water Quote from: "flkeysaqua"...my boat runs 42 or 43 with a good head wind You mean "tail wind"?
seems like each time out over the past 2 or 3 weeks, the top speed has been slowly increasing. 1st run: 31 mph3rd run: 35 mph5th run: 37 mph7th run(today) 42.8 mph! (36 mph into 15 knt wind)i raised the motor up 1 hole and cupped the prop. now at WOT it reaches 5800 rpm, and now it instantly gets up on plane... im thinking it was just slow because the carbs where gummed up and after a few tanks ran through it, its all cleaned out! the cupping helped a ton, it can handle way more trim without cavitating... im still itching for more power though :twisted:
Sound like carb gumming and/or cylinder port carbon build-up. Either way, what you have discovered is a boat rule:Boats like to be run - idle boats have problems. or:Use it or lose it. Either way, regular use of boats and the engines that power or support them (mains and generators) keeps things running well. Neglect, whether by maintenance or use, will allow degradation.
