196 Rebuilds
1973 196 rebuild question
17
18
19
20
44
Topic: 1973 196 rebuild question (Read 24291 times)
July 26, 2024, 05:53:10 PM
Reply #255
dbiscayne
Re: 1973 196 rebuild question
Reply #255 on:
July 26, 2024, 05:53:10 PM »
not sure what Aquasport did from the factory, but Grady Whites include a drain through the rear bulkhead of the fuel tank coffin that dumps into the rear bilge, no plug, for the outboard models and they also don't foam the tanks in. Inboard models keep the coffin area isolated.
July 27, 2024, 08:59:16 AM
Reply #256
Reply #256 on:
July 27, 2024, 08:59:16 AM »
That makes sense, actually.
July 27, 2024, 01:59:19 PM
Reply #257
Reply #257 on:
July 27, 2024, 01:59:19 PM »
To add a little to the context, The biggest danger to the tank, if it's metal, is water. The drain hole is to let any water that gets in, to escape to the bilge. Hopefully there will not be any gas leaking from a new tank.
July 27, 2024, 06:00:40 PM
Reply #258
Reply #258 on:
July 27, 2024, 06:00:40 PM »
No joke on a leaky new tank. That would be a real bummer.
Bulkhead fully glassed in. Very solid.
On the front bulkhead, does anyone ever use a piece of Coosa or ply and extend it it high enough for the front casting deck to rest on? I was either going to get rid of the front deck or make it bigger and taller. I throw a cast net a lot and think I will miss the casting deck and it would be better taller. Thoughts are always appreciated.
July 28, 2024, 10:30:48 AM
Reply #259
Reply #259 on:
July 28, 2024, 10:30:48 AM »
Bulkhead looks solid. Also, the top of the transom came out nice.
July 29, 2024, 07:53:37 PM
Reply #260
Reply #260 on:
July 29, 2024, 07:53:37 PM »
Thanks Ricky. I appreciate it and the tutelage prior to it coming out the way it did. Does anyone ever use a piece of Coosa or ply for the front bukhead and make it tall enough for the front casting deck to lay on?
I was looking at the 196 gull with the console against the casting platform and thought how cool it would be if the center of the bulkhead, however wide the console is, were tall enough to be the front of the center console. Seems like no advantages to doing it though.
July 30, 2024, 05:08:30 AM
Reply #261
Reply #261 on:
July 30, 2024, 05:08:30 AM »
I would stick with making another bulkhead and glassing it into the stringers. This will help with fighting twist as the hull moves through the water. It will make the stringers, bulkheads and the hull itself all one. Plus it will allow you to seal up the bilge from the top of the deck. I looked through all your pics and I can't see one that has a casting deck in it. Do you still have the original?
July 30, 2024, 07:43:47 AM
Reply #262
Reply #262 on:
July 30, 2024, 07:43:47 AM »
Think it was dbiscayne's . I will look for it.
July 30, 2024, 10:54:46 AM
Reply #263
dbiscayne
Reply #263 on:
July 30, 2024, 10:54:46 AM »
Original console layout of the 1971 Gull model, and underside of the console shelf.
July 30, 2024, 02:36:24 PM
Reply #264
Reply #264 on:
July 30, 2024, 02:36:24 PM »
Did you keep that boat? Looks extremely fishing, beer drinking, diving, swimming,etc functional, but looks can be deceiving
July 30, 2024, 03:53:35 PM
Reply #265
dbiscayne
Reply #265 on:
July 30, 2024, 03:53:35 PM »
Yes still have it I'm a hoarder of boats. In the process of moving the console back just a bit, not as far back as a traditional center console but the forward Gull layout induces a lot of motion when it's anything more than choppy. I will say this - when anchored and fishing off the back it's a great setup. But if someones casting up front and you're driving it's duck or bleed time.
July 30, 2024, 08:47:03 PM
Reply #266
Reply #266 on:
July 30, 2024, 08:47:03 PM »
Dry fitted tank. When I removed this tank it was not strapped down and had foam all around it but no coffin so it's nose stuck out of a mountain of foam Into empty space so I really have no guide. I do have pics fr9m Ricky's build and others. Looking for the must haves like bottom supports that allow air flow. I do not know what's important. Where does the vent need to be in relation to the fill and fuel pick up etc, help and thanks.
July 31, 2024, 05:45:10 AM
Reply #267
Reply #267 on:
July 31, 2024, 05:45:10 AM »
You said that you are having a tank made, is it a duplicate of the one you show? Did you take measurements of where the original was before you took it out? What I'm getting at is the placement of the tank affects the way the boat sits in the water and the center of gravity. You built and installed a rear bulkhead. What told you that is where it should have gone? When I built mine, the original tank was above the tank, so I had no hints at where my new under the deck tank was to go.
July 31, 2024, 01:27:48 PM
Reply #268
Reply #268 on:
July 31, 2024, 01:27:48 PM »
Answers to your questions:
# I put the rear bulkhead where I removed the old one from. Exactly where it came from.
# I did not take any measurements on old tank because it was just laying in the bottom, no straps, foam randomly poured all around it, etc.
# I am having a duplicate tank made because it is the right height, width and capacity
# if you look at the rigging troughs on the starboard stringer and compare them to tank measurements you can Infer where the tank should be "ish". For instance, the fill tube goes through the trough angled towards the front, so I am guessing the forward end of the tank ends roughly there. The tank is 66 inches long and happens to fit perfectly between the rear bulkhead and the forward angled rigging trough
# was hoping to glean some info by scouring the 196 rebuilds
July 31, 2024, 01:37:12 PM
Reply #269
Reply #269 on:
July 31, 2024, 01:37:12 PM »
Oh yes, for sure dbiscayne, hoarder of boats. I know the feeling. In my barn right now is a 14 aluminum jet boat, another 14 foot aluminum jon boat, an 11 foot whaler (which is for sale) that was my first boat when I was 7, I'm over 50 now, the aquasport 196, and 3 other boats at different locations. Really need to consolidate but wont.
17
18
19
20
44
196 Rebuilds
