Author Topic: RickK's 170 rebuild  (Read 78785 times)
March 09, 2014, 07:39:20 PM
Reply #675
Re: RickK's 170 rebuild
« Reply #675 on: March 09, 2014, 07:39:20 PM »
Pop-up cleat install is deluxe.
Agree, on the final install, go with the ny-loks.
March 10, 2014, 04:50:38 AM
Reply #676
Aquasport Commodore
« Reply #676 on: March 10, 2014, 04:50:38 AM »
Quote from: "RickK"
That's where I bought them too - small world  :salut:
Are you located in Sarasota area?  Planning on coming out to the next gathering the first weekend in May at Buncee Pass?  Great way to meet some local members and it usually lasts about 4-6 hours.  The party before and after is also fun  :wink:
I'm just south of you, Port Charlotte. I will be there if I am off. I wont be in my Aquasport, so don't hold that against me. (it wont be done :oops: )
March 10, 2014, 05:07:26 AM
Reply #677
« Reply #677 on: March 10, 2014, 05:07:26 AM »
Come on out - doesn't matter what you're in.
March 10, 2014, 05:19:02 AM
Reply #678
Aquasport Commodore
« Reply #678 on: March 10, 2014, 05:19:02 AM »
Do you trailer up or drive up there through the ICW
March 10, 2014, 05:30:10 AM
Reply #679
« Reply #679 on: March 10, 2014, 05:30:10 AM »
We'll trailer up and launch at Ft Desoto - they have a HUGE ramp area and the place is monitored by the Rangers. Plus they have facilities.
March 16, 2014, 08:26:12 AM
Reply #680
« Reply #680 on: March 16, 2014, 08:26:12 AM »
Just received in the mail and need to get the backers installed before I flip the liner and set it in the boat.
I laid it out (with the help of Capt Matt  :salut: ), measured and marked it, then routed the plascore for the coosa backers.
March 16, 2014, 08:28:21 AM
Reply #681
« Reply #681 on: March 16, 2014, 08:28:21 AM »
Set the coosa in place
Cut the mat and cloth
March 16, 2014, 08:30:22 AM
Reply #682
« Reply #682 on: March 16, 2014, 08:30:22 AM »
Measured and documented everything for when it comes time to install the mount
Glassed them in
March 16, 2014, 08:35:55 AM
Reply #683
« Reply #683 on: March 16, 2014, 08:35:55 AM »
I finished bolting the rod holders in and then I put some 1/4" foam strips on the back of them since I'm not real certain how close to the hull they'll end up.  I assume there is some distance but this way if they are close and the hull flexes, like going over a wave, the holders won't make any noise.  May not need them but just in case.
March 16, 2014, 02:21:05 PM
Reply #684
dburr
« Reply #684 on: March 16, 2014, 02:21:05 PM »
Really nice Rick! The steady progress is really impressive  :salut:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
March 16, 2014, 07:15:04 PM
Reply #685
« Reply #685 on: March 16, 2014, 07:15:04 PM »
Thanks Dave.
To finish up the weekend I flipped the liner over on the saw horses, finished the ends of the liner that I had cut off and re-attached last weekend and also cut in the cleats. Port.
Starboard - both liner tops look plenty thick now to support the cleats and if someone attempted to lift the boat by them.
And marked where the "puck" of the trolling motor mount will go.
March 16, 2014, 08:28:40 PM
Reply #686
« Reply #686 on: March 16, 2014, 08:28:40 PM »
Excellent work, Rick! :thumleft:  :thumleft:
March 22, 2014, 03:02:51 PM
Reply #687
« Reply #687 on: March 22, 2014, 03:02:51 PM »
Started the day off with my buddies Dave and Ed helping me hoist the liner into the boat.  Took all of 5 minutes but was awkward.
March 22, 2014, 03:06:43 PM
Reply #688
« Reply #688 on: March 22, 2014, 03:06:43 PM »
As you can see there is some scribing and cutting to make it fit.  Anyway, these (and above) pics were taken at 10AM.
Kinda figured the liner would not allow the fill hoses under the sides so I'm glad I planned the fill to come up in front.
The front portion of the sole is where the casting deck will sit (you can see where I cut the casting deck out of the liner), so the sole will be supporting the casting deck about a foot at least.
March 22, 2014, 03:10:26 PM
Reply #689
« Reply #689 on: March 22, 2014, 03:10:26 PM »
The following pics were taken at 2PM.  Got her all scribed in.  Had to trim it about 8 times but slowly got it cut in.
Next is to put in the casting deck and see how much I need to trim off the front of the liner.  Since I raised the floor the height and angle of it has changed a bit.
