How'd you like that actual math - old style without a phone or calculator
Quote from: "RickK"How'd you like that actual math - old style without a phone or calculator I that how you do that? I have forgotten how to do math without a phone or calculator :!: Looks great Rick.
Quote from: "Callyb"Quote from: "RickK"How'd you like that actual math - old style without a phone or calculator I that how you do that? I have forgotten how to do math without a phone or calculator :!: Looks great Rick. I could loan you a slide rule...
I didn't fill the honeycomb on the edges this time so there is a little air at that spot. The rest it tight. I was more worried about how the cloth would follow the curve of the edge.Here was the lam schedule:1 layer 1808 against the lid and up the edge of the outer lip1 4" wide 1808 strip along the front edge of the lid to support it better - had a cracking problem there before1 3/4oz matt the size of the plascore to give the 1808 and 1708 a little grip1 1708 the size of the plascore1 piece 3/4" plascore wet out on both sides1 1708 the size of the 1708 on the outer side1 layer 1708 to cover it all and up the edge of the outer lipShould be stout as can be. Took every bit of 50oz of epoxy to lam it up.I just removed the blocks and plastic and it's looking pretty good. Weighs about 10 lbs now.
It's about 1.5" short all the way around, 'cept the front
