Author Topic: Ex-Aquasport/Wellcraft employee (Bob C)...  (Read 30966 times)
April 06, 2010, 03:38:49 PM
Reply #375
cdoyal
Re: Ex-Aquasport/Wellcraft employee (Bob C)...
« Reply #375 on: April 06, 2010, 03:38:49 PM »
My bad... :oops:
Although I do know the neighbor kid who's about 6' 6" and doesn't weigh more than 150 pounds. He does have freakishly long arms....
1997 245 Explorer w/225 Johnson Ocean Runner
April 06, 2010, 04:19:27 PM
Reply #376
« Reply #376 on: April 06, 2010, 04:19:27 PM »
Quote from: "cdoyal"
My bad... :oops:
Hey, I'm 6' 2" and go 165, I reached under there a BUNCH of times... :cheers:
April 14, 2010, 03:41:39 PM
Reply #377
cdoyal
« Reply #377 on: April 14, 2010, 03:41:39 PM »
My bad... :oops:
Ok Monkey Boy. whatever!
On another note: What's the best way to remove cured 5200? Acetone?
April 14, 2010, 05:14:16 PM
Reply #378
« Reply #378 on: April 14, 2010, 05:14:16 PM »
Razor blade.
I don't think acetone will faze it.
April 14, 2010, 08:38:28 PM
Reply #379
« Reply #379 on: April 14, 2010, 08:38:28 PM »
Quote from: "Capt. Bob"
Razor blade.
If you soak the bond joint for a good while with acetone, it will "loosen" the bond, but it's still work to get separation!
April 14, 2010, 09:18:34 PM
Reply #380
cdoyal
« Reply #380 on: April 14, 2010, 09:18:34 PM »
Razor blade.
I've just removed an old transducer and the bracket was embedded in the stuff. When I pried it off, it even took some gel coat with it. I'm thinking acetone and a razor blade.
April 14, 2010, 09:36:05 PM
Reply #381
« Reply #381 on: April 14, 2010, 09:36:05 PM »
Heard tell this stuff works well..
When properly inserted.
April 14, 2010, 11:04:55 PM
Reply #382
« Reply #382 on: April 14, 2010, 11:04:55 PM »
Capt. Bob,
What kind of firecracker IS that?  Never heard of using such a firecracker on 5200, but I'm a quick learner.....
Nice unit..... :bom:
April 15, 2010, 05:32:10 AM
Reply #383
« Reply #383 on: April 15, 2010, 05:32:10 AM »
That would be the extended length version of the classic M-80.
Common name: "Crack Stick"  :bom:
April 16, 2010, 12:05:29 PM
Reply #384
« Reply #384 on: April 16, 2010, 12:05:29 PM »
Maybe I went to a different school but I don't think that is properly inserted!   :shock:
April 16, 2010, 09:18:37 PM
Reply #385
« Reply #385 on: April 16, 2010, 09:18:37 PM »
Quote from: "wingtime"
I believe I could alleviate the improper insertion issue... :mrgreen:
April 20, 2010, 04:02:38 PM
Reply #386
cdoyal
« Reply #386 on: April 20, 2010, 04:02:38 PM »
Meanwhile, back to boat stuff...
Anyone know what brand/model the scupper covers are on the Explorers? Mine are both missing and I'd like to replace whatever was there originally. Looks like there were three or fours screws holding it on.
April 20, 2010, 07:34:19 PM
Reply #387
« Reply #387 on: April 20, 2010, 07:34:19 PM »
Look like this?
http://content.westmarine.com/images/ca ... 593459.jpg
It's what's on my 91 WAC.
April 20, 2010, 10:28:11 PM
Reply #388
cdoyal
« Reply #388 on: April 20, 2010, 10:28:11 PM »
Look like this?
I'm not sure since they are missing. I think I saw some sort of cover over them in a photo in the Explorer literature that shows up sometimes here.
April 21, 2010, 08:02:54 AM
Reply #389
« Reply #389 on: April 21, 2010, 08:02:54 AM »
Kinda magical  :roll:
Looking through the 97 catalog, it appears those are what was used (like the WM link).
While you can't see them on every model because not all have shots taken of the transom, enough appear to confirm that this is the type Aqua used. It's what was used on my 1986 170 and currently on my 1991 210. There certainly other EXers out there who can chime in.
I'm assuming you mean the scuppers that drain your motor well on the Euro Transom. :idea:
Bob C should be able to confirm.
