Author Topic: Ex-Aquasport/Wellcraft employee (Bob C)...  (Read 30829 times)
March 17, 2010, 06:05:48 PM
Reply #345
Re: Ex-Aquasport/Wellcraft employee (Bob C)...
« Reply #345 on: March 17, 2010, 06:05:48 PM »
Quote from: "cdoyal"
CD,
Ignition and tilt/trim get their power through the engine harness.  If you put a meter on the red wire on you ign switch, it should read voltage with the key off.  This gives you trim/tilt.  Turn the key to "run", and the purple wire should now have voltage.  This enables your gauges and anything else that relies on ignition power...
Just to clarify, this power doesn't come from inside to boat (to use simple terms). It's all in the harness then directly from the motor to the battery.
CD,
That's correct.  The boat's harness and the engine harness are 2 entirely separate entities, though they share the ground.  That's it as far as "co-mingling"... :shock:
March 20, 2010, 09:55:49 AM
Reply #346
Robob
« Reply #346 on: March 20, 2010, 09:55:49 AM »
Seabob,
It's great to know you're here:-)
I recently bought a 1995 175 Osprey which surveyed A-1 and seems to be very solid.
Can I tip the console up to get at wiring and steering without destroying the live well plumbing?
I've gotten different answer from every former dealer I contacted.
Thanks in advance,
Bob on Tampa Bay
March 20, 2010, 10:58:20 AM
Reply #347
« Reply #347 on: March 20, 2010, 10:58:20 AM »
Bob,
That console should be installed with #14 lag screws, if I remember correctly.  Pretty sure it wasn't t/bolted.  Remove the screws, then lift up the back end, there should be enough slack in the feed and drain hoses of the livewell where you can probably lift her up about 6"-8" without bothering anything, maybe more.  Get a buddy to help you, and while he lifts, you lay on the deck and see just how much hose you can coax up from under the deck.  Just don't get carried away! :thumright:
March 21, 2010, 12:07:21 PM
Reply #348
Robob
« Reply #348 on: March 21, 2010, 12:07:21 PM »
Thank you very much:-)
That solves my problem.
Bob on Tampa Bay
March 25, 2010, 08:57:52 PM
Reply #349
stringali
« Reply #349 on: March 25, 2010, 08:57:52 PM »
Hey Bob,
I was showing my son that post you had written in regard to strengthening my hatch to the fish box.  What do you mean by let kick?  Hope that all is well.  I am looking forward to another great boating season.
Steve
March 26, 2010, 02:00:05 PM
Reply #350
« Reply #350 on: March 26, 2010, 02:00:05 PM »
Steve,
It's a term we use meaning harden, or kick-off.  It's when the catylist and the resin become one...very hard substance! :thumleft:
March 27, 2010, 05:35:56 PM
Reply #351
cdoyal
« Reply #351 on: March 27, 2010, 05:35:56 PM »
Bob to the white phone for an electrical question please:
I have a mini-harness going to the tach. There are several wires bundled together. Sender, ground, light, etc. One of the wires is purple (for the ignition, I'm assuming). Can I run all my ignition feeds off it?
Thanks,
Chris
1997 245 Explorer w/225 Johnson Ocean Runner
March 28, 2010, 09:04:32 AM
Reply #352
jdevoid
« Reply #352 on: March 28, 2010, 09:04:32 AM »
Seabob
2001 AS 225 EX - I found what appears to be future use wiring inside my cabin, Two sets dangling just under the port and starboard lights with finished ends. There is a good 8 ft extra wire in each coil.  I believe they are white wires. Any idea what they are for?
March 28, 2010, 11:27:22 AM
Reply #353
cdoyal
« Reply #353 on: March 28, 2010, 11:27:22 AM »
Quote from: "jdevoid"
Seabob
Funny you mention that. In redoing my dash, I found a mystery white wire too. No idea what it's for.
March 28, 2010, 11:58:55 AM
Reply #354
« Reply #354 on: March 28, 2010, 11:58:55 AM »
Thanks,
Chris
CD, yes you can.  Terminate the purple to the "I" post on your tach, then daisy chain to the other gauges...
March 28, 2010, 12:00:19 PM
Reply #355
« Reply #355 on: March 28, 2010, 12:00:19 PM »
Seabob
I'm pretty sure those are pull wires, especially if there is no ground accompanying them...
March 28, 2010, 04:01:08 PM
Reply #356
cdoyal
« Reply #356 on: March 28, 2010, 04:01:08 PM »
Thanks,
Chris
I've got a purple on my tilt wiring bundle too. I'll connect those two and daisy chain them all together.  Should take care of it.
My wife and I spent the afternoon fishing new wires from the forward bilge up to the helm. I think I owe her.
March 28, 2010, 09:27:58 PM
Reply #357
« Reply #357 on: March 28, 2010, 09:27:58 PM »
Bob i was at m surplus the other day and drove slow by wellcraft next door,nothing going on but they do have a security guard,and i also saw some boat molds out back,maybe that's why,anyway i was wondering if you worked out of there or the site on Whitfield.
March 29, 2010, 10:08:31 AM
Reply #358
« Reply #358 on: March 29, 2010, 10:08:31 AM »
Quote from: "Circle Hooked"
Scott,
I did about a 6 month stint down at plant 1 (by Marine Surplus) when they move the 225/250 Osprey and 230 Cat line down there, but got back to Plant 6 on Whitfield to wire Scarab Sports.  Plant 1 was a MISERABLE place!  So, 5 1/2 years on Whitfield, 6 months at Plant 1.
March 29, 2010, 06:05:12 PM
Reply #359
« Reply #359 on: March 29, 2010, 06:05:12 PM »
Plant 1 looks really old and decrepit - must still do some customer service or something out of there - seen some big Hydrasports and such there.
