Author Topic: 200 engine/transom  (Read 435 times)
February 20, 2019, 05:21:11 PM
Read 435 times
warrenltamargo
200 engine/transom
« on: February 20, 2019, 05:21:11 PM »
I had a problem with my 1987 175 hp Mariner engine over heating and after a lot of work I was told to add a jack to move the engine back away from the transom and lower it more.  The thinking being that the lower unit was not getting enough water in the pickup due to it being in the draft of the boats bottom.  Sure enough after doing the addition of the jack plate the engine runs perfectly normal.  Just wondering if anyone else has run into this situation? :confused1:
the ole fisherman whos best catch in his life keeps reminding him every day
February 20, 2019, 05:22:52 PM
warrenltamargo
Re: 200 engine/transom
« Reply #1 on: February 20, 2019, 05:22:52 PM »
Sorry forgot to mention this was on my 1987 200 aqua sport.
February 22, 2019, 10:23:00 AM
« Reply #2 on: February 22, 2019, 10:23:00 AM »
You should be able to put a yard stick on the bottom of your hull at the center of the transom and the cavitation plate of the motor should be level or 1" above the height of the transom.
February 24, 2019, 03:14:46 PM
warrenltamargo
« Reply #3 on: February 24, 2019, 03:14:46 PM »
Thanks wingtime
