Author Topic: '76 22 Osprey re-build  (Read 22787 times)
November 03, 2015, 01:14:17 PM
Reply #240
northfork
Re: '76 22 Osprey re-build
« Reply #240 on: November 03, 2015, 01:14:17 PM »
Yes Bob that was the company. Phil is really nice to work with. Seems to be the go to guy up here.
November 03, 2015, 02:44:04 PM
Reply #241
Que Pasa
  • NorthEast
« Reply #241 on: November 03, 2015, 02:44:04 PM »
Thanks guys, I was looking at poly since I wasn't going with a deck hatch. Dont the aluminum ones need to be sealed with glass?
November 03, 2015, 04:51:12 PM
Reply #242
« Reply #242 on: November 03, 2015, 04:51:12 PM »
If you have good airflow around an aluminum tank you don't have to do anything to them.
November 03, 2015, 05:02:00 PM
Reply #243
« Reply #243 on: November 03, 2015, 05:02:00 PM »
You plan to install below deck and cover over with no access, correct?
November 03, 2015, 08:08:27 PM
Reply #244
Que Pasa
  • NorthEast
« Reply #244 on: November 03, 2015, 08:08:27 PM »
Yes
November 04, 2015, 09:09:54 AM
Reply #245
« Reply #245 on: November 04, 2015, 09:09:54 AM »
Well then, since you're sealing the tank in, poly might give you a longer life because it will sweat under there.
As stated in other rebuilds, allow for expansion and mount it accordingly. We've seen poly tanks chafe when :thumright: not secured properly and end up leaking way before their lifetime.
November 04, 2015, 11:01:34 AM
Reply #246
Que Pasa
  • NorthEast
« Reply #246 on: November 04, 2015, 11:01:34 AM »
Thanks Bob, but after searchin the net for a poly tank I finally gave up and ordered a custom aluminum.
November 04, 2015, 11:03:35 AM
Reply #247
Que Pasa
  • NorthEast
« Reply #247 on: November 04, 2015, 11:03:35 AM »
Does anyone have the measurement of the original console base from the casting platform. I seem to have lost mine, I thought I gave it to north but cant seem to find it in the thread.
November 04, 2015, 11:26:32 AM
Reply #248
northfork
« Reply #248 on: November 04, 2015, 11:26:32 AM »
Que
I have the measurement at home in my log book. I will send it later.
November 04, 2015, 03:23:44 PM
Reply #249
Que Pasa
  • NorthEast
« Reply #249 on: November 04, 2015, 03:23:44 PM »
thanks north starting to plan out my floor
November 04, 2015, 04:46:15 PM
Reply #250
northfork
« Reply #250 on: November 04, 2015, 04:46:15 PM »
Que
Are you using your old console?
Who did you order your tank from?
North
November 04, 2015, 05:03:56 PM
Reply #251
Que Pasa
  • NorthEast
« Reply #251 on: November 04, 2015, 05:03:56 PM »
North yes I'm redoing the old console, going for the original look, no tower or t-top. And The tank is being made custom by a metal shop a friend of mine owns. It'll be 80 x 24 x 9, 76 gal.
November 05, 2015, 04:34:20 PM
Reply #252
Que Pasa
  • NorthEast
« Reply #252 on: November 05, 2015, 04:34:20 PM »
Looking for opinions on my floor, I dont plan on adding a tower or t-top. I was going to raise the floor 3 inches, I'm wondering if I can get away with 1 1/2"?
November 06, 2015, 10:48:00 AM
Reply #253
northfork
« Reply #253 on: November 06, 2015, 10:48:00 AM »
Que
The console was set back from the face of the front casting deck 28 1/2". (Not the lip the front face of the console)
I'm going up 1 1/2" on my deck as well unless I hear anything from others that it should go higher.
I made my new tank 84" long.
Chuck
November 08, 2015, 06:23:28 PM
Reply #254
Que Pasa
  • NorthEast
« Reply #254 on: November 08, 2015, 06:23:28 PM »
Gran, how far forward did you move your fuel tank? And do you feel you placed it right.
