Author Topic: '76 22 Osprey re-build  (Read 22843 times)
October 01, 2015, 12:43:06 PM
Reply #210
Que Pasa
  • NorthEast
Re: '76 22 Osprey re-build
« Reply #210 on: October 01, 2015, 12:43:06 PM »
I think 1" should be ok as long as I tab it in good. It will make another support point besides the stringers.
October 01, 2015, 02:42:30 PM
Reply #211
« Reply #211 on: October 01, 2015, 02:42:30 PM »
Your transom enclosure will also add some strength/support to the transom.  I think you will be fine with 1".
October 04, 2015, 08:34:36 PM
Reply #212
Que Pasa
  • NorthEast
« Reply #212 on: October 04, 2015, 08:34:36 PM »
Got a break in the rain and finished up the grinding, man am I glad to have that behind me.
October 08, 2015, 07:52:10 AM
Reply #213
Que Pasa
  • NorthEast
« Reply #213 on: October 08, 2015, 07:52:10 AM »
Today I started fitting the molded stringer sections into the hull. I will use pvc pipe as a drain tube in the bottom of the molds.
October 08, 2015, 12:56:17 PM
Reply #214
northfork
« Reply #214 on: October 08, 2015, 12:56:17 PM »
Que
Nice work on extending the stringers. Are you doing knees and if so are you going to tie them into your stringers.
I finished glassing in the port knee last night.
October 08, 2015, 06:43:53 PM
Reply #215
Que Pasa
  • NorthEast
« Reply #215 on: October 08, 2015, 06:43:53 PM »
North, I am going to put knees in. My thinking is extending the stringers back, and tabbing them in. Then doing something like Craig did with the knees. I keep changing back and forth as to whether to do the knees first or the stringers. Got some more work done today, I got some 1 1/2" PVC pipe and glassed in the drains, also reinforced the crack in the port stringer. I got the extensions on the stringers fitted also.
October 08, 2015, 07:04:49 PM
Reply #216
northfork
« Reply #216 on: October 08, 2015, 07:04:49 PM »
If you did the knees after the stringers are you going to put the knees on top of them or along side. Seem like if you did the knees first you could notch you
stringer extension around them.
October 08, 2015, 11:57:02 PM
Reply #217
Que Pasa
  • NorthEast
« Reply #217 on: October 08, 2015, 11:57:02 PM »
I thought about doing it that way but I'm going to do them separately and join them after.
October 09, 2015, 08:53:42 AM
Reply #218
Que Pasa
  • NorthEast
« Reply #218 on: October 09, 2015, 08:53:42 AM »
1/2 inch or 3/4 inch nida for the floor. Oops I meant coosa.
October 09, 2015, 10:12:27 AM
Reply #219
Que Pasa
  • NorthEast
« Reply #219 on: October 09, 2015, 10:12:27 AM »
Has anyone used core lite?
October 09, 2015, 11:44:23 AM
Reply #220
« Reply #220 on: October 09, 2015, 11:44:23 AM »
Not me.
October 09, 2015, 02:43:51 PM
Reply #221
« Reply #221 on: October 09, 2015, 02:43:51 PM »
October 09, 2015, 09:42:11 PM
Reply #222
Que Pasa
  • NorthEast
« Reply #222 on: October 09, 2015, 09:42:11 PM »
Spoke to the guys at Barnegat light Fiberglass they couldn't say enough good things about it. Looks like I'm going with the corelite.
October 12, 2015, 08:04:25 PM
Reply #223
Que Pasa
  • NorthEast
« Reply #223 on: October 12, 2015, 08:04:25 PM »
Que Pasa in the house. Got half the belly glassed, and tabbed in the knees. Tomorrow the stringer caps will go in.
October 13, 2015, 05:14:01 AM
Reply #224
« Reply #224 on: October 13, 2015, 05:14:01 AM »
 :thumleft:
