Gallery
Gallery
165/170/175 Rebuilds
My first rebuild. 76 170
Topic: My first rebuild. 76 170 (Read 3589 times)
October 17, 2014, 01:51:56 PM
Reply #60
Re: My first rebuild. 76 170
Reply #60 on:
October 17, 2014, 01:51:56 PM »
You could always carry a 5gal bucket with an aerator in it? Put it where ever you want.
October 17, 2014, 09:39:24 PM
Reply #61
bfabian76
Reply #61 on:
October 17, 2014, 09:39:24 PM »
lol. so i bought 3 sheets marine ply 1/2 inch. 10 yards 1708, 10 yards 1.5oz mat. 5 gal resin, bedding compound, and a new leaning post!
October 18, 2014, 07:15:13 AM
Reply #62
Reply #62 on:
October 18, 2014, 07:15:13 AM »
Sounds like you have all the fixin's.
New leaning post huh - let's see it 8)
October 18, 2014, 01:01:52 PM
Reply #63
bfabian76
Reply #63 on:
October 18, 2014, 01:01:52 PM »
October 18, 2014, 01:04:07 PM
Reply #64
bfabian76
Reply #64 on:
October 18, 2014, 01:04:07 PM »
started my template for the floor today. have to go to a one year old b day tomorrow.. then monday I will start cutting the new floor to get it fitted in.
October 18, 2014, 01:12:33 PM
Reply #65
Reply #65 on:
October 18, 2014, 01:12:33 PM »
Nice leaning post.
I'm going to have Randy, one of our local members, build something up for me when I get to that point - no room to store it right now.
October 18, 2014, 08:54:31 PM
Reply #66
bfabian76
Reply #66 on:
October 18, 2014, 08:54:31 PM »
thanks. I have an original AS leaning post I was going to use. but i got a deal on this one i couldnt pass up. i will rarely ever have the back rest on it, however I do need to have one made for it. never know. the ol lady might like it.
October 20, 2014, 02:59:08 PM
Reply #67
bfabian76
Reply #67 on:
October 20, 2014, 02:59:08 PM »
Update____ couldnt do any grinding or glass today because I had some stuff to do. however, i made my template for the floor, got the floor cut and fitted as well as the wood for raising my stringers. i used 1/4 to raise the stringers so im thinking that plus some 1708, plus the bedding compound will be right around 3/4 inch I need.
template was made with foam insulation board.
tomorrow I will get in, start grinding, build my area for the fuel tank, and start glassing the stringer tops.
October 21, 2014, 11:29:30 PM
Reply #68
bfabian76
Reply #68 on:
October 21, 2014, 11:29:30 PM »
got some itchy grinding done today.
used a sawzaw to get the bedding compound off.. holy hell that stuff sucks
took a break and snapped a pic
all the compound removed. stringers ground down
forgot to take a pic when i was done. but right now everything inside that needed grinded is done except for my liner lip, which i will tackle first thing in the morning. plans for tomorrow are as followed
grind liner lip
build new tank coffin
start fitting rigging tubes
fiberglass wood raisers to stringers/ tab stringers to hull.
October 22, 2014, 12:43:09 AM
Reply #69
larsli68
Reply #69 on:
October 22, 2014, 12:43:09 AM »
Great work! I'm afraid the floor will be my next job after I finish the transom.
October 22, 2014, 05:17:50 AM
Reply #70
Reply #70 on:
October 22, 2014, 05:17:50 AM »
Looking good - progress, progress, progress.
Don't forget that you will need to grind up the liner a little bit too, to be able to tie the sole into the liner - ties it all together. You'll need a fillet of thickened resin and then a couple small layers of cloth all around. If you tape it off you can keep control of the height of the grind.
October 22, 2014, 08:53:06 AM
Reply #71
bfabian76
Reply #71 on:
October 22, 2014, 08:53:06 AM »
Larsli68--- it's not too bad so far. Worst part was the bedding compound for me.
Rick- yea. Liner will be done today.
October 23, 2014, 12:51:46 AM
Reply #72
bfabian76
Reply #72 on:
October 23, 2014, 12:51:46 AM »
finished up my grinding today
tops of stringers glassed in with one layer of 1708. tabbed stringers to hull with two layers 1708.
in the morning i will finish building my new tank coffin and do some rigging. hoping my floor will be in by Saturday
October 23, 2014, 04:56:01 AM
Reply #73
Reply #73 on:
October 23, 2014, 04:56:01 AM »
Looks good
October 23, 2014, 09:45:13 PM
Reply #74
bfabian76
Reply #74 on:
October 23, 2014, 09:45:13 PM »
Thanks.its coming alone. I glassed my new fuel coffin today that I made. Also built a storage area right behind the casting deck in front of the tank.
