Author Topic: Need Help Identifying a 1981 CC  (Read 907 times)
April 09, 2014, 04:21:17 PM
Re: Need Help Identifying a 1981 CC
« Reply #15 on: April 09, 2014, 04:21:17 PM »
Quote from: "joesmomjen"
Thanks for all the info. The boat does have the 3-hatch coffin in the front, with 2 long hatches and a smaller hatch/cooler in the front of the coffin. On either side of the small hatch cooler and directly in front of it, the floor appears soft/springy. Is this normal? Wondering if it's due to their not being any support directly in this space. The rest of the floor appear solid.
Does that model have a deck hatch forward of the coffin between it and the anchor hold?
You are correct in that area having little support. The stringers are widely spaced and there isn't a bulkhead there. The deck can get a little "springy" with age due to the limited support but it also can suffer from core rot due to improper (or just old ) fasteners. The models with the deck hatch are noted for this. If it doesn't have the deck hatch, tap on the deck between the coffin and anchor hold and listen for the dreaded "dull" thud.
I had my 84 for 15 years and it was bouncy forward of the coffin but I never fell through. There is no support there save the deck itself. Besides, the deck can gain extra life with a simple but effective fix.
April 09, 2014, 05:17:14 PM
joesmomjen
« Reply #16 on: April 09, 2014, 05:17:14 PM »
Quote from: "Capt. Bob"
It does have the deck hatch there. When you say "the deck can gain extra life with a simple but effective fix", what needs to be done. Also, the fuel lines were replaced but the gas tank was not. Would it be safe to say I may be looking at having to replace the tank shortly? Looks like I would have to take the console out to be able to lift the cover over the tank.
I really appreciate everyone's input and I really like the boat. I just don't want to be getting into something I'm not equipped to handle
April 09, 2014, 05:51:08 PM
« Reply #17 on: April 09, 2014, 05:51:08 PM »
First, I'll need to do a search but we have a pretty detailed method of this repair. Here's a start.
http://classicaquasport.com/phpbb3/view ... 75#p105775
Next, if it's the original tank, then yes it has seen it's better days but.... You really don't know till you look. Pop the deck plates over the tank hatch and smell. That's one sure sign but I'd price the replacement of the tank in your offer for the boat. I'd allow a $1000 for the tank. You may also need to do hatch repair so you need to figure what your time is worth plus needed repair supplies. No one here has ever done an actual CCP tank replacement but...... We've all seen a guy do one once so....... :cheers:  :cheers:  :cheers:
You will need to undo the coffin box and the console. Slide the box forward and the console a little. You must detach the pedestal seats also. A couple of 2" x 4"s will help raise the console high enough to remove the hatch since you don't want to take all the wiring and control cables off. You should have enough slack to do this and have room to remove the tank. A friend helps with this. At least it did with the guy I saw. :mrgreen:
Plenty of threads on every model CCP with lots of pics. Very doable but yes.....$$$.
We can help......... figuratively.
Good luck. :thumleft:
April 09, 2014, 06:54:55 PM
joesmomjen
« Reply #18 on: April 09, 2014, 06:54:55 PM »
Thanks Capt Bob - I did find some information about fixing the deck right after I replied earlier. This may be getting into more that I want to, both in time and money. But, once done, the boat may last another 20 years  :cheers:
April 09, 2014, 09:42:58 PM
« Reply #19 on: April 09, 2014, 09:42:58 PM »
And that's understood, especially by me. I bought my 84 CCP in 95. Spent a year fixing it to my way of use. Put on a new motor (96) and did minimum fiberglass repair. I replaced the tank in 96 (ruptured after topping it off with 85 gals. and running in very rough seas). Replaced the tank and ran it for the next 14 years after which I sold it to charter member of this group who has owned as many or more Aquas than me and it's still going strong.
CCPs have a good record for stoutness and strong stringers. The deck and transom is  IMHO above average (my 84 is still original) so you take your chances. Members who rebuild them will have a lifetime boat and we have a good number on this Forum. Still, I chose my 91 because first, I had always wanted a WAC and second because the work it needed, I was comfortable with. It's been a great boat and I feel at ease with such an old hull. It took about a year to decide but I didn't want one I needed to tear apart so I get your concerns. You'll know when you find the right one.
Good luck and always remember, the best part of getting your boat is in the hunt. :thumleft:
April 10, 2014, 04:24:04 PM
joesmomjen
« Reply #20 on: April 10, 2014, 04:24:04 PM »
Thanks everyone. Think I'll try and establish a price and see where it goes
April 10, 2014, 05:34:51 PM
« Reply #21 on: April 10, 2014, 05:34:51 PM »
As Bob said, you have a 1981 model year 22-2 that was made in August of 1980 - just before Aquasport changed the design in 1981.  The biggest change was the console - the pre-1981 CCPs had the "old style" console and the post-1981 models had the "new style" console.  Some folks like the old version better than the new - it's a matter of taste and preference.  John Dupree has had both - it would be interesting to hear his opinion of new versus old...  :scratch:
Regarding your tank, Phil at Alloy Metal Works did the tank on my 22-2CCP - which is just like yours.   :cheers:  He has the drawings/specs and charged me $650 for the tank a couple years ago.  Alloy Metal Works contact info is in the Vendors section and be sure to ask for the Classic Aquasport discount!
As stated above, the deck can be a bit "springy" on each side and under the coffin, but should not be "soft."  The most common area for problems is between the anchor locker and the under-deck hatch/stowage compartment in front of the coffin.  You can remove the 12 screws holding the coffin down and lift the coffin up pretty easily - there is a pie plate under the coffin you can open and look inside under the deck.  Put a camera under there and flash a bunch of pictures and you can get an idea of the deck condition.  Also, you can remove the hatch in the deck in front of the coffin and check the edges of the decking for delamination.  It might be better than you think - good luck!   :wink:
