From the Tahoe forum, Scotty...http://www.tahoeyukonforum.com/forum/sh ... hp?t=42042Might want to join. Jessie and I both have Grand Cherokees, jeepsunlimited.com has helped us a bunch...
Quote from: "seabob4"From the Tahoe forum, Scotty...http://www.tahoeyukonforum.com/forum/sh ... hp?t=42042Might want to join. Jessie and I both have Grand Cherokees, jeepsunlimited.com has helped us a bunch... and you know me with my Ford truck forums! I would just replace the headlights with factory style units, and replace the bulbs with better brighter ones. most factory head light assemblies done work well with HID's as the beam pattern is quite different.
The Sylvania Silver-Star Ultra bulbs are the best bang for your buck Scotty. You might need some new plastic housings... check with LMC truck for those.
I replaced one of my headlights on the f250 a couple months ago, ordered from rockauto.com good prices, and quick shipping
Guys, thanks again for your input.Played it safe and went with the Sylvania Silver Star Ultras. Did not want to go full-bore with an external power source for the big boys.The Sylvania's installed easily on the Tahoe. A big improvement, especially on low beam.The high beam, while impressive and a lot more than stock, didn't seem to be "All That". Coming home every night in the dark, there are deer on my road like you wouldn't believe. So researched Gary's suggestion. When on high beams, the relay also combines the low beams. You're running all four lights Installed today. What a difference. This is a BRIGHT setup, well worth the 28 bucks for the relay assembly.Couldn't be happier....thanks guys
