Author Topic: Replacement Headlights  (Read 868 times)
January 31, 2014, 08:11:16 PM
Read 868 times
« on: January 31, 2014, 08:11:16 PM »
Been sprucing up the old Tahoe.
The bluish-beam headlights....are they legal everywhere? Are these the ones known as projectors?
Been checking the net...some seem to be halide, some LED. Is there a "best" brand, one you guys know of and are pleased with?
Thanks! :thumright:
January 31, 2014, 08:51:20 PM
Re: Replacement Headlights
« Reply #1 on: January 31, 2014, 08:51:20 PM »
HID (high intensity discharge)
Xenon gas excited between an arc.
 Color produced is the bluish you see.
High pressure sodium (crime lighting) is pinkish.
Low pressure sodium is yellowish.
Metal halide (mercury) bluish white
All are light produced by exciting gas between an electric discharge.
Wife has them on her car.
January 31, 2014, 08:56:26 PM
« Reply #2 on: January 31, 2014, 08:56:26 PM »
From the Tahoe forum, Scotty...http://www.tahoeyukonforum.com/forum/sh ... hp?t=42042
Might want to join.  Jessie and I both have Grand Cherokees, jeepsunlimited.com has helped us a bunch... :salut:
January 31, 2014, 09:20:34 PM
« Reply #3 on: January 31, 2014, 09:20:34 PM »
and you know me with my Ford truck forums!
I would just replace the headlights with factory style units, and replace the bulbs with better brighter ones. most factory head light assemblies done work well with HID's as the beam pattern is quite different.
January 31, 2014, 09:59:54 PM
« Reply #4 on: January 31, 2014, 09:59:54 PM »
Quote from: "Aswaff400"
And my Maxima forum!  http://forums.maxima.org/1st-2nd-genera ... 5-1988-19/
January 31, 2014, 10:52:45 PM
« Reply #5 on: January 31, 2014, 10:52:45 PM »
The Sylvania Silver-Star Ultra bulbs are the best bang for your buck Scotty.  You might need some new plastic housings...  check with LMC truck for those.
January 31, 2014, 11:06:17 PM
« Reply #6 on: January 31, 2014, 11:06:17 PM »
Quote from: "wingtime"
Once I get new housings for the Jeep, that's what I'm going with.  On a side note, the Maxima has glass housings...basically perfect after 27 years... :cheers:  :cheers:
February 01, 2014, 06:00:01 AM
« Reply #7 on: February 01, 2014, 06:00:01 AM »
I replaced one of my headlights on the f250 a couple months ago, ordered from rockauto.com good prices, and quick shipping
February 01, 2014, 07:56:08 AM
« Reply #8 on: February 01, 2014, 07:56:08 AM »
Rockauto is used a lot by the Jeep guys... :thumleft:  :thumleft:
February 01, 2014, 10:47:15 AM
gman 82 aquasport
« Reply #9 on: February 01, 2014, 10:47:15 AM »
Another thing to consider Scott, if your Tahoe is like mine when you switch your high beams on the low beams go off, Summit Racing and others sell a kit with relay that allows the low beams to stay on with the high beams thus getting you 4 lights on instead of 2 :thumright: Supposed to be a very easy wire up...have one on order for my 97 Tahoe..I'm also running "Silver Star" lights..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 01, 2014, 11:09:01 AM
« Reply #10 on: February 01, 2014, 11:09:01 AM »
Sweet!!
Thank you all for your responses....nothing like trusted guidance! :thumright:
February 11, 2014, 09:13:46 PM
« Reply #11 on: February 11, 2014, 09:13:46 PM »
Guys, thanks again for your input.
Played it safe and went with the Sylvania Silver Star Ultras. Did not want to go full-bore with an external power source for the big boys.
The Sylvania's  installed easily on the Tahoe.  A big improvement, especially on low beam.
The high beam, while impressive and a lot more than stock,  didn't seem to be "All That". Coming home every night in the dark, there are deer on my road like you wouldn't believe.
So researched Gary's suggestion. When on high beams, the relay also combines the low beams. You're running all four lights :shock:
Installed today. What a difference. This is a BRIGHT setup, well worth the 28 bucks for the relay assembly.
Couldn't be happier....thanks guys :salut:
April 16, 2014, 12:16:04 PM
SaltH2OHokie
  • Mid Atlantic
« Reply #12 on: April 16, 2014, 12:16:04 PM »
While not DOT approved, if you have fog lights...they also disappear on most vehicles when you switch to high-beams.  On both of my F350's, a little google'ing and I found which wire under the dash to clip and ground and now they stay on with the high-beams.  Makes a surprising difference (at least on my 2 superduty's).  Something else to consider.
VA vehicle safety inspectors will sometimes check for fog lamps going off when high-beams come on, so when I did mine I grounded a pigtail and crimped a female bullet connector on it.  Cut the factory wire and put a female on the "downstream" side and a male bullet on the "upstream" side.  Now it takes 2 seconds to switch it back and forth from factory setup to "Ryan" setup.
My door dinger wire, on the other hand, just got snipped.  No connectors necessary, because that ain't ever going back.  Most obnoxious sound I can think of when I'm just trying to leave the doors open to hear the radio while I'm sitting on the tailgate!
Ryan
April 16, 2014, 01:31:26 PM
« Reply #13 on: April 16, 2014, 01:31:26 PM »
Funny you mention that Ford door chime, Ryan.  Where we live, the closest parked vehicle (other than our driveway) would be like 4-500 feet away.  I can always tell when a Ford truck pulls up and the door opens... :x
April 16, 2014, 01:46:49 PM
SaltH2OHokie
  • Mid Atlantic
« Reply #14 on: April 16, 2014, 01:46:49 PM »
Black with pink tracer leaving the steering column.  Snip, done.
Ryan
