Author Topic: 1987 Aquasport CCP222  (Read 23168 times)
March 23, 2014, 09:15:22 PM
Reply #240
Re: 1987 Aquasport CCP222
« Reply #240 on: March 23, 2014, 09:15:22 PM »
WOW X2.
VERY impressive. Pros can't take the time to get a job like this :thumright:
March 23, 2014, 10:11:33 PM
Reply #241
fishinonthebrain
« Reply #241 on: March 23, 2014, 10:11:33 PM »
Thanks Gran.
Here is my next mold to build. A console designed after a Mako that was sitting over at Bas Pro shops. What a nice looking boat. Then I added a seat and raised the console 4" for a toe kick. The toe kick was added not just for the toes but to hide the install led lights.
1987 222CCP current rebuild.
March 23, 2014, 10:51:17 PM
Reply #242
« Reply #242 on: March 23, 2014, 10:51:17 PM »
Nice!
You will like the toe-kick. Makes for a really clean install too, since its screwed to the deck from inside.
Guess you'll core it?
March 24, 2014, 10:10:32 AM
Reply #243
dburr
« Reply #243 on: March 24, 2014, 10:10:32 AM »
That is some piece of cabinetry!!!!  :thumright:  Wow!!
In the picture the corners on the bump for the live well do not look like they have been radiused yet is that just because of the picture angle?
As an after thought what about making a flange on the vertical side of the new face to give you a tab surface that is molded to the new piece? That would give you a surface to glue direct to the liner and then you can tab over that to make that whole joint stronger.  Added step and more time but it might make for easier fairing in the boat because you would not be fairing in the corner but "on the flat"..
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
March 24, 2014, 10:21:12 AM
Reply #244
« Reply #244 on: March 24, 2014, 10:21:12 AM »
The Radio Flyer wagon seals the deal... :thumright:  :thumright:
March 24, 2014, 07:15:29 PM
Reply #245
fishinonthebrain
« Reply #245 on: March 24, 2014, 07:15:29 PM »
Nice!
Yes your right I plan to make a flange on the floor to attach the console down. I will need to core a good bit of the console because I want to attach the t-top directly to the console not the deck.
March 24, 2014, 07:21:09 PM
Reply #246
fishinonthebrain
« Reply #246 on: March 24, 2014, 07:21:09 PM »
Quote from: "dburr"
After I screwed the two pieces together I did notice I missed routing the radius. Good eye! The first thing I have to do is take the two pieces apart. Not too big of a deal.
The vertical form overlaps the existing liner by a few inches so the fairing will be done on a flat area. Another good point though.  :mrgreen:
March 24, 2014, 07:24:28 PM
Reply #247
fishinonthebrain
« Reply #247 on: March 24, 2014, 07:24:28 PM »
My sons been looking for that wagon. Have to keep that quite.  :wink:
April 04, 2014, 10:22:29 PM
Reply #248
« Reply #248 on: April 04, 2014, 10:22:29 PM »
The transom mold is coming out sweet! Your a few months ahead of me with a similar layout so its nice to see it happen before I take a stab at it. Looks awesome cant wait to see more progress.
April 05, 2014, 08:33:17 AM
Reply #249
« Reply #249 on: April 05, 2014, 08:33:17 AM »
Man that looks great!  Awesome job!
April 06, 2014, 12:54:57 AM
Reply #250
fishinonthebrain
« Reply #250 on: April 06, 2014, 12:54:57 AM »
Thanks guys for the positive support.
I have been working on the outside of transom prepping it for gelcoat and prepping this transom cap mold all last weekends thru the week after work and all this weekend. Been taking lots of pictures so I should have a good progress report maybe tomorrow night or early next week.
April 06, 2014, 06:12:46 PM
Reply #251
fishinonthebrain
« Reply #251 on: April 06, 2014, 06:12:46 PM »
As promised been working on this segment since last weekend. Even took a couple days off during the week to get this part of the project going.
Took form apart routed some more edges, formed clay radius, re-primed, 5 coats of wax and three coats of peel ply.
Sprayed multiple coats of straight gelcoat no duratec additive. Of course every bug in town had to visit. :roll:
April 06, 2014, 06:20:21 PM
Reply #252
fishinonthebrain
« Reply #252 on: April 06, 2014, 06:20:21 PM »
Screwed the two forms back together and started to form the clay radius.
Simple easy way to sculpt the clay with a socket and extension then wipe it again with your finger and presto perfect radius.
April 06, 2014, 06:38:02 PM
Reply #253
fishinonthebrain
« Reply #253 on: April 06, 2014, 06:38:02 PM »
1 layer of 3/4oz. CS, 4 layers of 1708, then 4 additional layers at turn up of 8" wide 1708.
Then two layers of 3/4" Coosa at turn up for rod holder support and two layers of Nidacore to flush out the bottom of the live well gutter so the live well mount and seal.
I will go back and add two more layers of 1708 over Coosa and Nidacore.
April 06, 2014, 06:51:38 PM
Reply #254
fishinonthebrain
« Reply #254 on: April 06, 2014, 06:51:38 PM »
Flipped form on its side to work on other side.
Filled cracks and ends of nidacore with thickened vinyle ester/ cabosil. Then 4 layers of 1708 over everything. In the bump out for the live well I added 1 layer of Nidacore and 1 layer of 1708.
We had a front come thru last night... :roll: ... so to speed up cure I added a tent and halogen light for heat.
