Author Topic: 1987 Aquasport CCP222  (Read 22167 times)
April 07, 2014, 08:05:53 PM
Reply #270
fishinonthebrain
Re: 1987 Aquasport CCP222
« Reply #270 on: April 07, 2014, 08:05:53 PM »
Quote from: "RickK"
That's pretty light - I would have guessed 150-200 with all that resin in there.  Cool, not too heavy.
I think if I would have followed the normal plywood base and multiple layers of glass it probably would have reached those weights. This was a perfect application of the nidacore with inserts of coosa where needed.
1987 222CCP current rebuild.
April 07, 2014, 09:30:57 PM
Reply #271
Callyb
  • MidWest
« Reply #271 on: April 07, 2014, 09:30:57 PM »
Fish! That looks super! All the prep really payed off, very well executed. :salut:
As a side note, you did a really good job prepping that mold too. There was a good amount of complexity to it and you only had those few small areas that stuck. That is truly a feat in itself.
When i popped the bait well out i had the same situation, all joy for me and most everyone else was pretty much ho hum about it. I know what you did there, and you did it very well. :wink:
Carl
___________________________
April 07, 2014, 11:12:41 PM
Reply #272
fishinonthebrain
« Reply #272 on: April 07, 2014, 11:12:41 PM »
Quote from: "Callyb"
Thanks Carl I appreciate it.
I could have put a light taper to the gutters but man talk about more complexity. The sucker would have pulled off a lot easier but man I want to get thing done. I want to go fishing this year.   :mrgreen:
April 08, 2014, 09:17:09 PM
Reply #273
« Reply #273 on: April 08, 2014, 09:17:09 PM »
that is AWESOME!!!! love it!!!
April 09, 2014, 11:46:14 AM
Reply #274
fishinonthebrain
« Reply #274 on: April 09, 2014, 11:46:14 AM »
thanks Koz.
You must be gearing up for your rebuild soon as it's getting warmer?
April 10, 2014, 12:04:05 AM
Reply #275
« Reply #275 on: April 10, 2014, 12:04:05 AM »
It's finally a human temp around here. I'm itching to pull the cover. Maybe in a month or so. I have a punch list to get through on my buddies Grady so he can launch by mid may and we can fish. I'm a bit tight on funds so I probably won't post much for another month or so. But, once I get started I will obsess and make good strides. I'm hoping to have something that floats by the fall.
April 10, 2014, 09:01:27 PM
Reply #276
fishinonthebrain
« Reply #276 on: April 10, 2014, 09:01:27 PM »
Florida196 was asking about filing in the transom cutout with glass and I had just did that same thing on my rebuild so here it goes. I had a lot of drop pieces of 8" wide 1708 so I laid in as many pieces that was needed to just about flush out with the existing fiberglass. Then using a straight edge as a guide I grinded all the excess glass of and got the transom pretty flat. After a huge pile of fiberglass I rolled on some high build duratec primer.The first picture shows a before then after.
Before
After
Then I will spread a generous layer of polyester filler and fair this baby out with a long sanding board.
April 10, 2014, 10:31:58 PM
Reply #277
« Reply #277 on: April 10, 2014, 10:31:58 PM »
Looks awesome - did you mix your own polyester filler?  Or buy a product made for that?  I am close to doing that on my boat, but I'm not sure what to use for filling/fairing.
April 10, 2014, 10:56:39 PM
Reply #278
fishinonthebrain
« Reply #278 on: April 10, 2014, 10:56:39 PM »
Quote from: "CLM65"
Evercoat polyester glazing and putty mix. Purchased it at the fiberglass supplier I receive all my supplies at.
It is real smooth and feathers out real good. Only for light imperfections because it has no structural value.
April 11, 2014, 08:34:39 PM
Reply #279
florida196
« Reply #279 on: April 11, 2014, 08:34:39 PM »
Looks great that's what I will try to accomplish on my hull.  Thank you for the pics ur doing a great job.
April 11, 2014, 08:39:12 PM
Reply #280
« Reply #280 on: April 11, 2014, 08:39:12 PM »
Quote from: "fishinonthebrain"
Quote from: "CLM65"
Thanks for the info!
