CCP correct?
You stated "deck drainage" meaning the area you walk on and can physically see correct or are you talking below deck i.e. the bilge?
Water on the deck will drain to the rear corners and will flow overboard (via displacement).
Water in the bilge is another thing and yes you need a float switch or auto pump to handle that. Unless you have a compromised sealing of the deck or of the deck drain hoses or their corresponding thru hull connections or you left the brass drain plug out :o you shouldn't be getting enough water in that bilge area to swamp the boat. Water can also enter via the tank coffin cover, hatch openings/deck plates, the fish "coffin box" drain and any and all penetrations (think gunnel rod holders in stern area or raw water/livewell thru hull fittings).
You do not want to plug those corner deck drains when the boat is stored in the water.
If you don't have a CCP, kindly disregard.
