Paint removal off Fiberglass
Topic: Paint removal off Fiberglass (Read 1602 times)
December 27, 2005, 03:19:01 PM
Read 1602 times
Mr. Osprey
December 27, 2005, 03:19:01 PM »
While doing my new black boot, I smudged a liitle black above the tape on the white fiberglass. Will acetone do the trick?
Mr. Osprey
1971 Mako 17 Angler
1986 Evinrude 88 SPL
December 27, 2005, 10:24:00 PM
December 27, 2005, 10:24:00 PM »
It probably will. Just be careful. It's easy to make a bigger mess. Be sure and wax the spot afterwards.
December 28, 2005, 05:45:01 AM
December 28, 2005, 05:45:01 AM »
Mr. Osprey - not to be TOO stupid here - what are you referring to when you talk about a boot? the bottom paint? Just never heard it called that before, that I can remember.
JJ, never noticed that your boat has a tower. How's that workin' out for you? How do you get up there? I don't see an easy way to climb up - maybe I'm missing something.
December 28, 2005, 08:02:19 AM
Tailgunner
December 28, 2005, 08:02:19 AM »
I think he means boot stripe.
Tailgunner
Now in BroadBill\'s hands
December 28, 2005, 11:23:04 AM
Mr. Osprey
December 28, 2005, 11:23:04 AM »
When I refer to a boot, I am talking of the boot striping above the bottom paint, just like Tailgunner said.
Mr. Osprey
1971 Mako 17 Angler
December 29, 2005, 07:13:14 AM
December 29, 2005, 07:13:14 AM »
Thanks, guess I never new that the stripe actually had a name - learn something new everyday (dumb name for it though)
December 29, 2005, 08:40:27 AM
JimCt
December 29, 2005, 08:40:27 AM »
To add to the confusion, the name for that stripe up here is boot top.
JimCT
\'74 22-2 inboard
HIN:ASPL0953M74J
Chrysler 318
\'74 Marshall 22
December 29, 2005, 11:41:04 PM
December 29, 2005, 11:41:04 PM »
Rick,
I love the tower. It looks kinda homemade but it sure helps spotting tarpon and cobia. It's not as pretty as what one normally sees but it works. Getting up is no problem. I step on the gunnell then step on the braces on the side. Getting in is a problem, especially when you are old and stiff like me. The inverted "V" on the side is impossible to squeeze through. Like it is I have to swing around and duck under the back side. (previous owner was NOT very tall.) I'm going to modify the "cage". I plan on moving the side braces to straight up and down at the corners. Hopefully this creaky body can deal with that.
December 30, 2005, 08:06:25 AM
December 30, 2005, 08:06:25 AM »
John, as long as you're safe up there and it works - who cares what it looks like. "If it ain't broke...."
