Author Topic: installing Macerator in explorer 225  (Read 782 times)
July 10, 2010, 11:19:34 PM
Read 782 times
fishingdave
« on: July 10, 2010, 11:19:34 PM »
I want to upgrade my fish box drain with a macerator pump, for the people who have installed them before, can i keep all existing wires and just upgrade the breaker in the front panel to a 20amp or do i need to install a relay in the stern and run something to the battery.
thanks
dave
2005 aquasport 225 explorer
2005 Yamaha 200F
July 11, 2010, 01:58:29 PM
Re: installing Macerator in explorer 225
« Reply #1 on: July 11, 2010, 01:58:29 PM »
Dave,
You'll also need to run a pair of 10GA wires, red forward to the switch at the helm, black to the ground bus on the starboard transom wall.  Macerators draw a lot more current than washdown or bilge pumps.  I'd replace the switch with a momentary on/off too.  Leave the pump on, water gets pumped out, pump runs dry...not good.
July 11, 2010, 03:41:52 PM
fishingdave
« Reply #2 on: July 11, 2010, 03:41:52 PM »
sea bob,
thanks for the insite, the switch is a great idea, but i think what im going to do is , keep the existing wires and breaker , replace the switch and install  a relay at the stern. I will use the existing line just for the relay trigger and run seperate fused line to the battery.
2005 Yamaha 200F
July 11, 2010, 04:48:26 PM
« Reply #3 on: July 11, 2010, 04:48:26 PM »
Quote from: "fishingdave"
sea bob,
Dave,
You can definitely do that... :thumleft:
July 12, 2010, 11:33:07 PM
WaveDancer
« Reply #4 on: July 12, 2010, 11:33:07 PM »
Dave,
Could you please keep a photo esay of what you are doing and post them as you go or post them up once you are done?
I own a 2004 AS Exporer and have the same problem almost every one else has with the factory setup.
Thanks.
WD.
Join CCA Northwest http://www.ccapnw.org.  If sport fisherman unite, and act as one, we can achieve anything we want, our numbers are to great to ignore.
July 14, 2010, 11:44:38 PM
fishingdave
« Reply #5 on: July 14, 2010, 11:44:38 PM »
sure will do! I should have diy in like two weeks. I will be installing shore power on the boat this week, i might create a diy for that too.
Dave
2005 Yamaha 200F
