Engines & engine woes
What size outboard to run?
Topic: What size outboard to run? (Read 1101 times)
July 05, 2009, 05:45:28 PM
Read 1101 times
BigFishin82
July 05, 2009, 05:45:28 PM »
Hi everyone . I am a new member here and I want to start by saying thankyou everyone for this awesome website and great atmosphere on here. Nothing better then good info and good people to share with. I just bought a 1978 25 ft. aquasport center console and I am wondering what size outboard I could use on my new boat? What can I use if I choose a single outboard ? What is ideal for twin setup also? I want to know the best route to go. Thanks again you guys.
July 06, 2009, 05:24:59 AM
Re: What size outboard to run?
July 06, 2009, 05:24:59 AM »
Welcome aboard BigFishin82 :!: :!:
Now we need to find out what kind of boat you just bought. Was it a 246 CCP? I'm not sure they made an Osprey that big back then. Here is a look at the literature from around 1980 - scan through this and I think you'll find the HP ratings of the boat.
http://www.classicaquasport.com/gallery/showphoto.php/photo/2849/sort/1/cat/572/page/1
Also, post some pix so we can help you figure this out.
July 06, 2009, 07:41:18 AM
BigFishin82
July 06, 2009, 07:41:18 AM »
Ok it is a 246ccp with the coffin box up front and 16 rod holders. I will take some pics today and post them later tonight. Thanks for the link Rick.
July 06, 2009, 09:34:42 AM
Hardwater
July 06, 2009, 09:34:42 AM »
Welcome BigFishin82! Another big CCP on board - when you have a few minutes add it to the list here:
viewtopic.php?f=1&t=3847
As far as power goes...DOCREED ('89 250 CCP) and Kamikazee ('82 246 CCP) may be able to provide some performance data and have some suggestions. Doc is running a pair of 150hp Mercs on a full bracket while Kamikazee has a single Johnson 250hp.
Let's see some pics :!:
\'86 222 CCP
\'88 Mercury 200hp Black Max
July 06, 2009, 11:50:32 AM
Kamikaze
Guest
July 06, 2009, 11:50:32 AM »
My Johnson 250 V8 pushed the boat at 42 MPH (GPS) @ 5500 rpm running a 15.25 X 18 pitch stainless prop. Motor developed tons of torgue and threw the boat on plane but it WAS far too heavy for a boat that sits low in the stern by design and needless to say it never passed a gas station that it didn't like - the best MPG I ever got regardless of speed was 1.65.
I have read in other posting that a 235 pushed the hull at 40 MPH as well, but I suspect it just took more time to get there.
Just this weekend I hung a 1999 Merc 3.0L EFI 225HP that I believe will push the boat just fine. I am also looking into "stern lifting" props as well to help plane the boat quicker. It will be a couple of weeks before I can report on the performance of the new motor as I didn't realize you just can't hook up Merc control cables to a OMC binnacle and assume it would all just work!
I will have pics soon on another project that you might find interesting as well. More to follow..
Anyone looking for a 246 Fish Box in good condition?
Kamikaze
July 06, 2009, 04:47:20 PM
July 06, 2009, 04:47:20 PM »
A 3 litre Merc 225 or 250, or really any V-6 outboard at around 250HP is a nice setup on a 246CCP. They are rated for 280HP, so you can also run twin 115s, 130s, or go a little over rating to twin 150s. I think twin V-6s on the transom is a bit heavy - a couple V-4s might work... You used to see a few 246 models with a big V-8 OMC motor, but they are heavy!
I would probably look at a 225/250 Optimax or Etec. Both have a good power/weight ratio, are good on gas, and you can pick one up without having to get a Federal bailout loan...
Don't forget to list your CCP with the others on the CCP listing:
viewtopic.php?f=1&t=3847&start=60&st=0&sk=t&sd=a
See ya on the water!
