Engines & engine woes
what motor would you put on a 170 ?
Topic: what motor would you put on a 170 ? (Read 994 times)
May 14, 2009, 09:57:27 AM
Read 994 times
sunflats
May 14, 2009, 09:57:27 AM »
Let’s say you have the time, the money and resources to rig your dreamed Aquasport 170, what motor would you put on ?
Regards
Robert
May 14, 2009, 12:33:38 PM
Re: what motor would you put on a 170 ?
May 14, 2009, 12:33:38 PM »
Maybe a jet outboard? 8)
May 14, 2009, 01:20:33 PM
flkeysaqua
May 14, 2009, 01:20:33 PM »
Well if that’s the case I would throw a Johnson second effort 250 tricked out to about 400 hp
But if you want a economical fishing machine then I'd probably go with a 90 yammy four stroke or a yammy hpdi
73 19-6 w/140 Evinrude
May 14, 2009, 01:35:41 PM
May 14, 2009, 01:35:41 PM »
http://smalloutboards.com/j5598.htm
May 14, 2009, 05:12:14 PM
Marcq
May 14, 2009, 05:12:14 PM »
If money was not an issue, I would go twins Mercury 30hp 4 stroke EFI, at 172lb each motor, it wouldn't put to much weight in the back. And I think it would look way cool a 170 with twins
Marc..
May 16, 2009, 11:27:33 AM
May 16, 2009, 11:27:33 AM »
170s benefit from a lightweight motor on the transom - they don't like a big hunk 'o metal back there. So for overall price, weight, and power, I think an inline 3 or 4 cylinder 90-115 HP would be the way to go. The Suzuki 90 is a good choice as a 4 stroke - only 350 lbs... The 90 eTec is 320 lbs. The 115 Merc Optimax is a little heavy...
For flats fishing, I like Rick's idea - the 75-90HP jet outboard - maybe a little heavy, but you could really go into skinny water!
Cost no object - I would consider a pair of 36 HP Yanmar diesel outboards - run one for great trolling or cruising economy, and crank them both up for some speed. But at $8000 a pop, that's a lot of $$$
May 16, 2009, 07:20:33 PM
May 16, 2009, 07:20:33 PM »
if money where no option and while we're already talking crazy, either a 300xs merc, or a 350 yami (804 lbs!!!) or one of them merc racing outboards like you'd see on a f-1 tunnel hull
but really, i would put a 115 yami 4 stroke jet drive(415 lbs) on a jackplate, talk about running in some shallow water
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
1989 Fountain 12-meter
SOLD
1992 Talon F-20
SOLD
May 17, 2009, 08:01:47 PM
No Class
May 17, 2009, 08:01:47 PM »
Lots of humor here! 70-90 2 stroke. 4 strokers are just too heavy. My son has an 18' center console(not AS) with an older 90 Merc & it will top 35 with 2 aboard in a 2' chop.
May 26, 2009, 12:05:23 PM
jsakat1
May 26, 2009, 12:05:23 PM »
I have a 130 Yamaha on my 170....so far so good. I would have a 115 four-stroke yammi if money was no object or 150 Yamaha 2-stroke with a little reinforcement of the transom
1987 170 Striper
