Hello:just got into a partnership on this boat {3 of us} it's my 1st boat and I'm excited about it !
One last thig on the Motor,were thinking about having the oil injection disabled and mixing our own oil in so this doesn't happen again ? {thoughts !!}
we also want to get the bottom of the boat redone !, were just not sure what to do ? I'd like to get it done as the motor is being worked on,but I have no idea how much this could cost ? or even whats the best method/product to use ?
Also ,were looking into getting 2 NEW bunk mattress's ,not sure where to get them ??
thanks guys !!the boat will be in a slip in Mamaroneck,NY and only trailored a few times a year to Montauk/south shore LI.
had another question about this boat,were looking at getting a combo FF/GPS unit and we were asked if the boat has a solid or hollow fiberglass hull ???were lookin at the lowrance hd7 83/200 khz TD ?
RickK :Thanks for all of the advice !!I found a painter very close toi the boat that uses very inexpensive help.he's currently in FL on vacation,and said to call him at the end of the month.he said roughly around $325.00 and mentioned using a primer,then a red under paint ? ,Then a color of my choice {Blue} and said he would use Micron ????does this sound like a good paint job ??
I've been looking at replacing the teak on the boat,that PlasTeak stuff looks fantastic !{I just got a sample from them}they make pulpits out of the stuff and sell powerwinch windlasses to mount on the pulpits ! {looks fantastic}I want to do the door to the cabin,as well as the side-gunnel caps.has anyone used this stuff ?thanks again,Bill
Billfish,Your hull is solid glass, so you can use a shoot-thru-the-hull ducer. I would go with Garmin, to be honest with you. We do a lot of Suzuki and Etec installs, their gauges are made by Lowrrance, and there have been a lot of issues with them.As far as a replacement tank, you will have to cut a "hatch" in the cockpit sole to remove the old one. Contact Wellcraft CS to get the builder who fabbed the tank to get another to the same dimensions. (941) 753-7811. They will direct your call to Four Winns CS (that's where some Wellcrafts are being built now), and explain what you need. Once you get a new tank, take the section you cut out and turn it into a hatch.Sounds easy, doesn't it?
