Engines & engine woes
2001 Johnson 225 tilt trim unit interchange
Topic: 2001 Johnson 225 tilt trim unit interchange (Read 331 times)
May 02, 2018, 10:11:24 AM
Read 331 times
Warreneberle
May 02, 2018, 10:11:24 AM »
Looking to pick up a lightly used unit to replace mine. I know my part number but can not find one. There are units out there with different part numbers but look the same. Anyone know if they are interchangable?
May 04, 2018, 11:42:18 AM
Re: 2001 Johnson 225 tilt trim unit interchange
May 04, 2018, 11:42:18 AM »
I believe all the V6 and V4 Units are just about the same. The valving for the reverse kick up might be different on the V4 models.
