Author Topic: Modifying 22-2 ccp tank coffin  (Read 649 times)
December 24, 2017, 08:30:08 AM
Read 649 times
luv2fishonaboat
« on: December 24, 2017, 08:30:08 AM »
Purchased a 100 gal. Moeller tank from the marine connection Ft.Pierce to replace the 85 gal. aluminum tank to find it wouldn't fit, length x width x height of poly tank are perfect if the coffin walls where removed. Has any anyone modified a coffin to accommodate a new tank?
December 24, 2017, 10:01:06 AM
Re: Modifying 22-2 ccp tank coffin
« Reply #1 on: December 24, 2017, 10:01:06 AM »
I have not modified a coffin (I did build one though) but make sure you leave enough room for the poly tank to grow once gas is put in it.  Grows 1+ percent in all directions.
December 24, 2017, 12:29:08 PM
luv2fishonaboat
« Reply #2 on: December 24, 2017, 12:29:08 PM »
With that being said...it wont work then. Any way to repair aluminum tank without welding? I've been reading about marine tex (grey) and cloth to make repairs....any suggestions?
December 26, 2017, 11:26:26 AM
  • Information Online
« Reply #3 on: December 26, 2017, 11:26:26 AM »
What is wrong with it?  If it is leaking due to corrosion - it's time for a new tank.  Phil at Alloy Metal Works has the dimensions and can have you a new tank in a week or so...
December 28, 2017, 04:03:57 PM
« Reply #4 on: December 28, 2017, 04:03:57 PM »
It’s certainly possible to modify a tank coffin, but it would probably be more work than removing it and adding under deck bulkheads to create a new coffin.  Even that might not work for the Polly tank, since the stringers get wider at the bottom anyway.
As others have said, the best option is probably to get an aluminum tank welded up for you.  It’s not cheap, but in the end, it’s the simplest best rout.  I would be reluctant to patch a corroded tank.  JB weld would be at best a stopgap.  If you have some visible corrosion, then there is likely more that you can’t see.  It only takes some vapors and a spark.
