1. Is there any concern with the access hatch to be located in the center console? I assume you will have the batteries there as well? I want to do the same to eliminate deck water from constantly being in contact with the access cover seal.
2. Is the front seat going to be a cooler or livewell or both? I see a drain plug in the bottom. Is that drained to a through hull at the transom or bilge?
3. Is that the original console that has been modified with the floor flanges cut off? Thank You
Going to be hot on the feet in the summer time!
