Gas tank - how many Gallons?
Topic: Gas tank - how many Gallons? (Read 1716 times)
September 29, 2006, 01:40:40 PM
Read 1716 times
hookdup
September 29, 2006, 01:40:40 PM »
Looking for some input here on how big of a tank to use in a '69 222. the floor has been ripped out and we're down to stringers (see Free Hull thread for photos). Basically I can do whatever i want with the tank and put it wherever i want. thoughts or comments?
I currently have a 39 gallon tank that i am thinking will go under the console. But i'm open to advice.
Also - Joe Vinson, the gentleman that gave me this hull runs a top-notch boat dealership in St. Augustine and I urge you to stop by if you are in the area. Great inventory and great people. Thanks again, Joe!
September 29, 2006, 02:25:51 PM
September 29, 2006, 02:25:51 PM »
Does Joe have a website?? Maybe we can toss some business his way.
Regarding the tank, a bunch of 222's have been rebuilt here "on the site" so maybe somebody's got an original you can lift dimensions from. Failing that, you can draw up a tank that would fit your space available. If you do, keep in mind the filler and vent location and under-deck clearences needed.
September 29, 2006, 09:56:51 PM
hookdup
September 29, 2006, 09:56:51 PM »
the tank i have is 25"x20"X9" = 39 gallons. it fits pretty snugly to the top of the stringers. i'll go check out some of the projects.
September 30, 2006, 08:59:47 AM
September 30, 2006, 08:59:47 AM »
Wow. 39 gallons would not get me very far. My '78 22-2 has an 85 gallon (original??). It also has a 32 under the front deck but I have never checked it out. I'm not about to put liquid gold (gasoline) in there until I have a chance to check to make sure it's clean and replace the hoses.
September 30, 2006, 12:09:18 PM
Foxhole
September 30, 2006, 12:09:18 PM »
My 1976 222 has a 56 gallon and I added a 12 gallon as a spare tank. I have had the tanks out several times. You may want to leave yourself the option of moving the tank forward or aft to help balance the boat. The old Aquasports are known for sitting low in the A$$. I moved my tank forward about a foot to help compensate for this. The only problem is this is trial and error. You build the boat, load it and put it in the water and check the balance. Then drain the tank and move it according to your needs. If you are using a jack plate plan on going forward a little. Also check the stringers for waterlogged foam while you have the flore out. I suspect I have wet foam in my stringers I just cant figure out how to get it out without cutting the flore out. Good luck
Foxhole
1976 222, 150 merc 10in jack plate, fuel flow scan, hydraulic tabs and steering, radar, 7.5 merc kicker. 36 volt trolling motor. she is a oldie but goodie!
My 8 year old races dirt oval karts. It is all about the kids learning to drive and race safety.
Foxhole MotorSports
Proudly Sponsored by
www.Stitchesofoz.com
Dress shirts for us with beer bellies.
October 17, 2006, 04:04:56 PM
fpalmer
Guest
GAS TANK
October 17, 2006, 04:04:56 PM »
I have a 1977 22 2 AS found orginal tank mfg. maybe they did your tank for your flatback also ?
RDS MFG.
Richard Carr 850-584-6898
Perry,FL.
rcarr@RDSaluminum.com
Richard was a PRINCE to deal with, professional, reasonable and timely !!! He actually faxed me the orginal drawings from 11-2-77. my tank fit in like a kid glove.
Good Luck
Frank
October 22, 2006, 04:42:53 PM
Mechanical Master
CCP gas tank
October 22, 2006, 04:42:53 PM »
Hookdup - you have a CCP, which means you have a stock 85 gallon aluminum tank under the seat/console. It is normally plumbed for twin outboards, but often one hose is plugged when only one engine is installed. The tank sits in a fiberglass well - yours should look like mine - ou can check out the pictures at:
mhttp://www.classicaquasport.com/galler ... 500/page/1
There is also room to mount a 50-80 gallon tank in front of the original tank if you want. The area under the deck between the gas tank enclosure and the bow is basically open - except for a storage locker/well in the floor near the bow on some boats. So if you needed 140-170 gallons - you can do it!
October 22, 2006, 09:45:48 PM
October 22, 2006, 09:45:48 PM »
Yep. My CCP has a 32 gallon in front and the 85 under the seat has two pickups. Someone teed the two pickups on the rear tank together so I left it like that. I assume the front tank was done at the factory because the floor has never been cut. There is a valve at the left rear
inside
an inspection plate for switching tanks.
October 29, 2006, 01:14:06 PM
Joe Vinson
Hookdup
October 29, 2006, 01:14:06 PM »
hookdup
How is the boat coming along, made any headway.
