Engines & engine woes
Oil leaking from between lower unit and prop
Topic: Oil leaking from between lower unit and prop (Read 481 times)
June 03, 2016, 08:55:14 AM
Read 481 times
taylorw13
June 03, 2016, 08:55:14 AM »
2000 Johnson 115 v4 is leaking oil between lower unit and prop, anyone know what is causing this and how to fix. Thanks in advance for any help.
1999 175 Osprey with 2000 115 Johnson
June 03, 2016, 10:48:40 AM
love2fish
Re: Oil leaking from between lower unit and prop
June 03, 2016, 10:48:40 AM »
without a picture, I'm going to guess it's "blue" oil, probably coming from the exhaust ports,,, just unburned oil. hook it up to ear muffs in your yard and let it run for a bit- it"ll burn off.
my 2-stroke Yamaha did that once.
Chris
\'74 22-2
Member #921
June 03, 2016, 12:31:35 PM
taylorw13
June 03, 2016, 12:31:35 PM »
I got off the water there was nothing leaking hooked ear muffs up to flush out with freshwater and noticed it after I had got done cleaning the boat. it used to just leak a little which I was told was normal, but now it seems serious. ( I still have vro hooked up)
June 03, 2016, 12:33:55 PM
taylorw13
June 03, 2016, 12:33:55 PM »
this picture was taken a while back
June 03, 2016, 02:52:48 PM
love2fish
June 03, 2016, 02:52:48 PM »
that's exactly what mine did. made a nice little puddle of stuff. has only happened once.
just watch it
Chris
\'74 22-2
Member #921
June 03, 2016, 03:17:58 PM
June 03, 2016, 03:17:58 PM »
Reading:
http://classicaquasport.com/smf/index.php?topic=7095.msg125148#msg125148
http://classicaquasport.com/smf/index.php?topic=5322.0
http://classicaquasport.com/smf/index.php?topic=9727.0
June 03, 2016, 03:21:27 PM
June 03, 2016, 03:21:27 PM »
Typically it comes from long idling before you put it on the trailer. If its gearoil it will smell strong and a little sulfury like gear oil, if its oily 2 stroke exhaust it will smell like gasoline.
