Flatback 22-2 Rebuilds
new 222 rebuild
16
17
18
19
22
Topic: new 222 rebuild (Read 77404 times)
August 22, 2007, 10:22:55 PM
Reply #240
Reply #240 on:
August 22, 2007, 10:22:55 PM »
Lookin' good!
August 23, 2007, 05:30:49 AM
Reply #241
Reply #241 on:
August 23, 2007, 05:30:49 AM »
Progress is a good thing.
August 24, 2007, 12:50:11 PM
Reply #242
captdave
Reply #242 on:
August 24, 2007, 12:50:11 PM »
Shine.... what are the deminsions of your fuel tank and where did you get it?
Dave
August 24, 2007, 01:21:04 PM
Reply #243
Shine
Reply #243 on:
August 24, 2007, 01:21:04 PM »
66 gallons. I have lost my scratch pad with the dimensions. I was lucky to find one surplus that fit really well without sacrificing capacity.
I dont think my dimentions would help much though, my sole height and sole thickness are not original. I bought it down the road in Ft. Pierce from Marine Liquidators
August 24, 2007, 01:45:57 PM
Reply #244
Reply #244 on:
August 24, 2007, 01:45:57 PM »
Shine-
I know you added material to your stringers and bulkheads (yellowish white) to increase sole to stringer bonds... what material did you use? I was thinking I might follow suit.
Gracias.
August 24, 2007, 01:56:51 PM
Reply #245
Shine
Reply #245 on:
August 24, 2007, 01:56:51 PM »
rich,
Those are called "cleats" and they can be made of anything that is stif and will bond will with epoxy, in this case i used what was left from the 2" thick transom foam. BTW 2" is overkill, a 1" cleat is plenty. We specify 3/4" wood stock for cleats on most of our wood/epoxy/glass boat designs
If at that time I had these nice composite brackets (used for the underside of the hull/deck joint) , I would have used long lengths of them for cleats....
August 24, 2007, 02:10:33 PM
Reply #246
Reply #246 on:
August 24, 2007, 02:10:33 PM »
That's a very good idea also. I'll look back at your post and I may fabricate some of those for myself... I would definitely like to increase the bonding surface of my stringers / sole.
Thanks.
September 04, 2007, 04:44:24 PM
Reply #247
Reply #247 on:
September 04, 2007, 04:44:24 PM »
Shine... check your PM.
8)
September 05, 2007, 03:22:38 PM
Reply #248
captdave
Reply #248 on:
September 05, 2007, 03:22:38 PM »
Shine... I checked out marine liqiudators they are good peeps. Called them on thurs with size needed they went and check their inventory called me back in hour and what do you know tank here next day. Plus it saved me couple hundred bucks rather than having one made mine is 56 gallons and I went with a poly tank.
September 06, 2007, 09:19:59 AM
Reply #249
Shine
Reply #249 on:
September 06, 2007, 09:19:59 AM »
Dave, glad it worked out.
Richard, I do not see a PM ?
September 06, 2007, 04:02:28 PM
Reply #250
Reply #250 on:
September 06, 2007, 04:02:28 PM »
I sent you one... don't understand. I just want to get some of that hatch channel from you.
September 06, 2007, 08:05:59 PM
Reply #251
Reply #251 on:
September 06, 2007, 08:05:59 PM »
Rich, check your PM "Sent" and "Outbox" to see what is there.
September 21, 2007, 11:50:56 AM
Reply #252
Shine
Reply #252 on:
September 21, 2007, 11:50:56 AM »
Hey remember me
Gluing up the the hatch lips, which have a drain built into them. The pieces are made on a mold, they we will fit together with a 45 degree miter cut (which is filled with epoxy glue).
Here is the profile.....
Here is the first piece being glued up...
September 21, 2007, 01:19:52 PM
Reply #253
Reply #253 on:
September 21, 2007, 01:19:52 PM »
Nice! I will need to figure that out for my boat soon.
November 14, 2007, 04:14:10 PM
Reply #254
Shine
Reply #254 on:
November 14, 2007, 04:14:10 PM »
Making scupper drain tubes from fiberglass sock. They end up looking like this...
They will run from the recesses in the sole (see below) to the transom.
We made them by waxing (and mold release) a 1" diameter (outside diameter) plastic rod, then laminated biax sock over it to make the tube. Ant more than 18" would be very difficult to get off :!:
for this tube we used three layers of the sock.
We are getting the leaning post/live well ready. We epoxy in 90 degree brackets (same as what we made earlier) to the sole. The leaning well will mount to the brackets, and we will glass a little from the inside. On the outside, it will be a smooth fillet transition.
also, the hatches are basically finished, and the bottom of the hull has been sanded down to original gelcoat. We will roll the entire bottom with epoxy to waterproof it forever (no blisters)
16
17
18
19
22
new 222 rebuild
