Author Topic: Jack Plate to raise the motor!!  (Read 1665 times)
February 18, 2014, 01:46:10 PM
Read 1665 times
gman 82 aquasport
« on: February 18, 2014, 01:46:10 PM »
Anyone out there running a jackplate (4-6 inch setback) on a Aquasport?
Looking at one to get my engine up to optimal height(mine is a 25  incher) right now it's about 1" to 1 1/2" to low and in the 3rd hole down..jackplate would be easier to use than to build up the transom and redrill higher..at least for now..
Any advise will be appreciated. :thumright:
Also are there any jackplates to stay away from..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 18, 2014, 04:05:58 PM
ceejkay
Re: Jack Plate to raise the motor!!
« Reply #1 on: February 18, 2014, 04:05:58 PM »
i had a jack plate on my 19'6. if your running shallow it defiantly helps as long as you dont go to high
February 18, 2014, 04:19:44 PM
« Reply #2 on: February 18, 2014, 04:19:44 PM »
I have a Bob's Machine manual jack plate on my 170.  I love it.  It was on the boat when I bought it.  I really like the fact that it moves the motor back out of the cockpit giving you more room in the boat.  I'm no authority on jack plates but around here Bob's machine are the most popular.
Here's a pic:
February 18, 2014, 05:09:11 PM
gman 82 aquasport
« Reply #3 on: February 18, 2014, 05:09:11 PM »
Thanks ceejkay and wingtime :thumright: , thats the info I am looking for..the jack plate will be used to get the motor to the right height and then locked in place , not looking for a powered one, just one to raise my 25 inch 150 up so the cavitation plate is where it should be...looking at a 4 or 6 inch setback.. :salut:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 18, 2014, 05:38:50 PM
« Reply #4 on: February 18, 2014, 05:38:50 PM »
bobs machine has a nice manual one that can be converted to hydraulic later down the road if you wanted... i think they make it upto 14 inch setback...http://bobsmachine.com/Standard-Versa-J ... HP_c15.htm
i had a 6 inch setback hydraulic plate on my osprey, loved it!! allows the boat to run in skinny water...
you can see how shallow the water is in this pic, and the cavitation plate is right at the waters surface...
February 18, 2014, 08:15:56 PM
« Reply #5 on: February 18, 2014, 08:15:56 PM »
Good news with the Bob's manuals is they are adjustable upward while in the water.
February 18, 2014, 08:46:40 PM
Blue Agave
« Reply #6 on: February 18, 2014, 08:46:40 PM »
Getting the cavitation plate up where it belongs will improve the ride and fuel efficiency.
1975 19-6
3.0 EFI Mercury 150 4S
March 05, 2014, 12:33:44 PM
SaltH2OHokie
  • Mid Atlantic
« Reply #7 on: March 05, 2014, 12:33:44 PM »
Jackplate question: does moving the weight back that 4-6 inches have any effect on the waterline at the transom?  What I'm driving at is my scuppers are already practically under water at rest with no added weight back there...would this shift in weight (plus additional 30lbs or whatever it is) make any practical difference in waterline at the stern?
Thanks,
Ryan
1975 Aquasport 19-6, 1985 Merc 115 Inline.
1970 Aquasport 22-2, 1987(ish) Yamaha 115 V4.
Former owner of 1988 Aquasport 290 TM.
Currently on nothing but cell phone/air card.  Which severely limits internet time.
March 05, 2014, 05:44:24 PM
« Reply #8 on: March 05, 2014, 05:44:24 PM »
I doubt the setback will make much difference.  The added weight of the jackplate would probably do more.  Add some weight to the bow to shift the CG fwd.
March 05, 2014, 08:43:03 PM
Bergertime
« Reply #9 on: March 05, 2014, 08:43:03 PM »
Dang Aaron.. That is some skinny water Son!  Just sayin :cheers:
B
98 245 Osprey / Johnson 225
