Author Topic: 246 rebuild live from Delmarva!  (Read 12823 times)
November 18, 2013, 07:39:08 PM
Reply #105
4shore
  • Mid Atlantic
Re: 246 rebuild live from Delmarva!
« Reply #105 on: November 18, 2013, 07:39:08 PM »
Koz you and I are like minded across the board on this one. I think the core should be tabbed in as a unit.
Thanks for the reply on the pm. I am still trying to figure out what I want to do with that dead space behind the tank coffin. I really like what u did with yours. If you can shoot me the photos/ info on those molds I will be sure to get you my photos/info on my transom
I thought you were gonna do a SeaCast poured transom?
November 19, 2013, 09:58:39 AM
Reply #106
saltfly
« Reply #106 on: November 19, 2013, 09:58:39 AM »
I would tab in at each layer. All so fill between the akoma on the transom and the gunnels. Any air gap will allow condensation to build up in the air pockets. Just my thoughts. :thumleft:
November 19, 2013, 12:03:48 PM
Reply #107
4shore
  • Mid Atlantic
« Reply #107 on: November 19, 2013, 12:03:48 PM »
SaltFly,
I have filleted the edges all the way around and laid thickened resin down between each layer with a 3/8" notched trowel. This should be sufficient I would think. Opinions?
November 22, 2013, 01:14:31 AM
Reply #108
« Reply #108 on: November 22, 2013, 01:14:31 AM »
Quote from: "4shore"
I'll get you a more detailed play by play for the molds in the next few days. And yes, I am definitely going pourable transom for many reasons.
November 24, 2013, 05:58:54 PM
Reply #109
4shore
  • Mid Atlantic
« Reply #109 on: November 24, 2013, 05:58:54 PM »
Ok let me try to do a photo update here since I've been slacking n that department
Cutting the stringer back on both sides about 2'
November 24, 2013, 06:00:03 PM
Reply #110
4shore
  • Mid Atlantic
« Reply #110 on: November 24, 2013, 06:00:03 PM »
Transom torn out. The CSM that you see on the port side was ground out after the photo.
November 24, 2013, 06:19:50 PM
Reply #111
4shore
  • Mid Atlantic
« Reply #111 on: November 24, 2013, 06:19:50 PM »
Used Popsicle sticks bought from the local craft store and hot glued them together to get a profile of the inside of the transom. Then used this profile to trace out that shape to a piece of 1/4" door skin. We will use this door skin throughout the transom project to cut out the 3 core pieces, the tabbing,and the full sheets of glass .
November 24, 2013, 06:32:06 PM
Reply #112
4shore
  • Mid Atlantic
« Reply #112 on: November 24, 2013, 06:32:06 PM »
This is the door skin template cutout and installed to test fit it and drill the holes for the all thread that will be used to clamp down the transom.
The small wooden blocks were hot glued across the transom to then hot glue Popsicle sticks across them to pick up the curve of the transom. That curve was then transcribed to the clamps so when we tighten it down it would retain that curve
November 24, 2013, 06:37:33 PM
Reply #113
4shore
  • Mid Atlantic
« Reply #113 on: November 24, 2013, 06:37:33 PM »
Wife grinding and digging out the old transom. Choose your women wisely fellas!!!!!
November 24, 2013, 06:41:27 PM
Reply #114
4shore
  • Mid Atlantic
« Reply #114 on: November 24, 2013, 06:41:27 PM »
Motor cutout done on template. Ended up being around 3' wide. This should be wide enough to facilitate hydraulic steering.
November 24, 2013, 06:42:41 PM
Reply #115
4shore
  • Mid Atlantic
« Reply #115 on: November 24, 2013, 06:42:41 PM »
Inside clamping
November 24, 2013, 06:45:10 PM
Reply #116
dburr
« Reply #116 on: November 24, 2013, 06:45:10 PM »
A picture is worth a 1000 words.... Now I understand how you used the Popsicle sticks to create a pattern.. Similar idea, a tad more creative, but the end result is the same.. From the looks of it the fit turned out relly well! :thumright:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
November 24, 2013, 06:45:43 PM
Reply #117
4shore
  • Mid Atlantic
« Reply #117 on: November 24, 2013, 06:45:43 PM »
Outside clamping. That is not an optical illusion. That 3/4" okoume is so damn stiff it was deflecting a clamp that was made up of two 2x4's and an 8' long section of steel hat channel!!
Needless to say I felt that with that type of pressure kerfing the core was a necessity.
November 24, 2013, 06:50:17 PM
Reply #118
4shore
  • Mid Atlantic
« Reply #118 on: November 24, 2013, 06:50:17 PM »
Cores cut out then round the edges and hot coat with thinned resin
November 24, 2013, 06:52:51 PM
Reply #119
4shore
  • Mid Atlantic
« Reply #119 on: November 24, 2013, 06:52:51 PM »
First layer of okoume pressed in and then waited a few days and released the clamps.
The stray white fibers you see are not sections of poorly wetted out glass they are just stray fibers that found their way onto the core.
