Family Fisherman/Dual Console/Sport Rider Rebuilds
246 rebuild live from Delmarva!
15
16
Topic: 246 rebuild live from Delmarva! (Read 13043 times)
July 31, 2014, 10:05:05 AM
Reply #225
Global Moderator
Re: 246 rebuild live from Delmarva!
Reply #225 on:
July 31, 2014, 10:05:05 AM »
Quote from: "4shore"
I can't help but notice how floppy the sides of this boat are. Is this normal?
Well "floppy" is a relative term. The Aquas I've owned had flex along the hull sides. How much flex is bad, I don't know. A mid tier boat, it isn't going to be as stiff as a higher end hull. These craft are known for being rather light for their length allowing lower HP to propel them. Sounds like a typical Aqua hull to me but I'm not pushing on it either so.....
Not a real comparison but just a weak example, your hull is listed at 2550 lbs. (probably dry) while a 23 Contender is listed at 4200 lbs. dry weight.
I'm thinking you're fine.
July 31, 2014, 10:21:14 AM
Reply #226
4shore
Mid Atlantic
Reply #226 on:
July 31, 2014, 10:21:14 AM »
Fair enough. I have also been thinking about adding bulkheads between the stringers when removing the floor. As far as I can see there are no bulkheads fore or aft of the fuel tank coffins. Will this cause stress points or anything else? Seems to be common practice around here to add them in.
July 31, 2014, 01:08:53 PM
Reply #227
Global Moderator
Reply #227 on:
July 31, 2014, 01:08:53 PM »
Well, we haven't seen a lot of negative comments from those who do, assuming they're still around to post them :o .
Again, why not? Might make it a little quieter when you're hunting ducks.
July 31, 2014, 02:05:38 PM
Reply #228
Reply #228 on:
July 31, 2014, 02:05:38 PM »
While you're in there, why not. It would give the deck more support too.
August 20, 2014, 07:37:01 PM
Reply #229
4shore
Mid Atlantic
Reply #229 on:
August 20, 2014, 07:37:01 PM »
Fishbox done. Top,bottom and sides all insulated with 2" foam and glassed in
Spray foam is just there to help round out the corners. The low spot is where the pedestal seat goes and its backed with 3/4" ply
August 20, 2014, 07:47:16 PM
Reply #230
Reply #230 on:
August 20, 2014, 07:47:16 PM »
How much you figure it/they weigh? Bet they look heavier than they are.
August 20, 2014, 08:10:56 PM
Reply #231
4shore
Mid Atlantic
Reply #231 on:
August 20, 2014, 08:10:56 PM »
30-50 is my guess. I can weigh it next time im working on it
March 17, 2016, 01:51:47 PM
Reply #232
TheKid
Reply #232 on:
March 17, 2016, 01:51:47 PM »
This rebuild still happening? I wanted to make seat boxes for a long time. Also need to recore fuel hatch.
Would be nice to see finished job.
March 17, 2016, 05:27:32 PM
Reply #233
Global Moderator
Reply #233 on:
March 17, 2016, 05:27:32 PM »
4shore hasn't been active on the Forum in well over a year (17 months).
June 01, 2020, 09:32:08 PM
Reply #234
4shore
Mid Atlantic
Reply #234 on:
June 01, 2020, 09:32:08 PM »
Hey guys. Been a while....
I still have this boat and actually have a second of the same model that has a hard top and an older optimax.
Long story short I have switched teams and am at the tail end of a seacraft restoration. On top of that I’m building a house and moving soon. I want these boat to go to someone who will finish up the project.
I’m willing to let the whole package go CHEAP! Please text me at 443-735-7062 as I don’t check this site frequently.
June 16, 2020, 09:44:58 PM
Reply #235
4shore
Mid Atlantic
Reply #235 on:
June 16, 2020, 09:44:58 PM »
Disregard.....sold.
15
16
