Flatback 22-2 Rebuilds
My 1971 222 flat back
Topic: My 1971 222 flat back (Read 2040 times)
June 22, 2013, 10:58:32 PM
Aquasport&AChevy
Re: My 1971 222 flat back
Reply #15 on:
June 22, 2013, 10:58:32 PM »
Oh and you know what I think you are right about it not being 222 I think it says 223 or something like that I forgot, my brother knows more details I just know it is a flat back. I'm here to just soak up as much knowledge as I can so I can rebuild this bad boy I'm no pro yet so I will be asking lots of questions lol!
June 23, 2013, 12:17:40 AM
Purgatory
Reply #16 on:
June 23, 2013, 12:17:40 AM »
Take a close look at the link and post us up some pics
viewtopic.php?f=3&t=10343
June 23, 2013, 08:11:56 AM
Aquasport&AChevy
Reply #17 on:
June 23, 2013, 08:11:56 AM »
Lets see how it works. This is just the transom I been getting it ready to grind.
http://s1287.photobucket.com/user/CaptG ... b.jpg.html
June 23, 2013, 09:53:39 AM
Aquasport&AChevy
Reply #18 on:
June 23, 2013, 09:53:39 AM »
Here is a inside look at the stringers and what not
http://i1287.photobucket.com/albums/a62 ... 4df809.jpg
June 23, 2013, 10:06:20 AM
Aquasport&AChevy
Reply #19 on:
June 23, 2013, 10:06:20 AM »
The first picture is just the outter transom to show the hull.
http://i1287.photobucket.com/albums/a62 ... d581ed.jpg
. The second is where I need some imput this is back by the transom where the bilge pump used to be and this is what I have been calling the "liner" and I really just wanted to know if people remove it or if they redo it. As you can see through the hole there is two walls the outside white wall and about a inch later it looks to be the real haul. I have seen people sand it down from there but mine looks like it can easily be pulled out? I don't want to do anything to it before I get some good advice here.
http://i1287.photobucket.com/albums/a62 ... 9c04a2.jpg
June 23, 2013, 10:31:41 AM
Purgatory
Reply #20 on:
June 23, 2013, 10:31:41 AM »
Yes, you definitely have a flatback!
What you are asking about IMHO is the inner fiberglass portion of the transom?
Most folks leave the outer portion, and cut off this inner portion with a skilsaw...then remove the plywood. This keeps the hull shape intact.
Hope this helps
June 23, 2013, 10:52:43 AM
Aquasport&AChevy
Reply #21 on:
June 23, 2013, 10:52:43 AM »
Well if you look at this picture you can see it alittle better because I already got out most of the transom, you can tell alot better where it is here and it just looks like it would come undone all the way to the front of the boat?
http://i1287.photobucket.com/albums/a62 ... 3ff7c6.jpg
June 23, 2013, 11:37:46 AM
Aquasport&AChevy
Reply #22 on:
June 23, 2013, 11:37:46 AM »
This is a good picture here of what I mean by it detatching if I undo the cap. It could be from my brother making the cuts too far up? Or maybe from cutting into the cap, he figured he could cut alittle out of the cap to redo the transom but maybe he went too far? Should I be worried about it coming off more and try and reseal it?
http://i1287.photobucket.com/albums/a62 ... 2d0a22.jpg
June 23, 2013, 12:27:50 PM
Purgatory
Reply #23 on:
June 23, 2013, 12:27:50 PM »
Wow, that definitely is a liner of sorts...you're right. Never seen one like that, pretty cool!
Heck yea, pull it out. Then when you're finishing up, glue it back in....that's gonna add a lot of strength to your hull sides.
June 23, 2013, 02:09:24 PM
Aquasport&AChevy
Reply #24 on:
June 23, 2013, 02:09:24 PM »
Haha nice I don't feel crazy now!!
June 24, 2013, 08:08:18 AM
Aquasport&AChevy
Reply #25 on:
June 24, 2013, 08:08:18 AM »
Quick update on my progress... Today I will FINALLY have the transom wood out and I'll be ready to grind the transom down. It took me two weeks working on it every afternoon when it's not so hot out but I must say for anyone that has this job please use a air chisel, I did mine all by hammer and chisel and it's a real bit@& lol my hands are all tore up and I think I broke my back but hell with it, it was all worth it! I'll post a picture when I have it grinded up and ready.
June 24, 2013, 08:14:32 AM
Aquasport&AChevy
A question about the cap
Reply #26 on:
June 24, 2013, 08:14:32 AM »
My cap looks to be on there pretty good and alot of screws are stripped so I was wondering if the best idea was to grind the screws out? What did everyone use to get theirs off? I'm open to anything, my brother and I could only unscrew about half of the screws on there so far.
June 24, 2013, 11:07:42 AM
Purgatory
Reply #27 on:
June 24, 2013, 11:07:42 AM »
Take a cutoff wheel or cold chisel to it.
June 24, 2013, 11:26:48 AM
Reply #28 on:
June 24, 2013, 11:26:48 AM »
Make sure you take some measurements and build some bracing before you remove the cap. The hull will probably want to distort when the cap is removed.
July 11, 2013, 08:19:23 AM
Capt Matt
Reply #29 on:
July 11, 2013, 08:19:23 AM »
My flat back had a liner in the bow between the casting deck and the cap
I removed it as I raised the floor and made casting deck smaller
Capt Matt
www.captmattmitchell.com
Light tackle sportfishing
