165/170/175 Rebuilds
RickK's 170 rebuild
66
67
68
69
93
Topic: RickK's 170 rebuild (Read 78207 times)
May 25, 2015, 04:56:45 PM
Reply #990
Re: RickK's 170 rebuild
Reply #990 on:
May 25, 2015, 04:56:45 PM »
I think it is ready
Everything is faired down to 180 grit. (Still on the first sheet of everything)
I used an air DA to sand the hullsides (Imron) with 220 grit.
I did find some dings in the hull that I filled and will have to fair those spots but otherwise it's ready for primer.
I know, I know, you're saying to yourself "Rick it looks the same as it has for the past month or so" - I can say that at 50 feet it looks the same but at 5 feet it looks and feels good.
May 26, 2015, 04:43:57 AM
Reply #991
larsli68
Reply #991 on:
May 26, 2015, 04:43:57 AM »
Looking great Rick! Fantastic job!
I will be focusing on my center console tonight. Prepping it for paint. I have given up on trying to do gelcoat repairs. It's just not possible without coating the hole thing...
I will put polyurethane paint on it.
Keep up the good work!
//Lars
May 26, 2015, 05:24:50 AM
Reply #992
Reply #992 on:
May 26, 2015, 05:24:50 AM »
Nice Rick! That's got to be a great feeling!
May 26, 2015, 06:56:25 AM
Reply #993
Reply #993 on:
May 26, 2015, 06:56:25 AM »
Thanks Lars and Craig - it'll feel better once it's primed. Man was it hot out there in the afternoon - smmmooookin' hot.
May 26, 2015, 09:49:21 AM
Reply #994
jfret
Reply #994 on:
May 26, 2015, 09:49:21 AM »
Nice work Rick.......hope to start on the fairing out and hull prep on my 196 soon. Ever decide on the paint?......so many options.
restoration in progress
Fat Baby
1974 Osprey 196
May 26, 2015, 10:22:27 AM
Reply #995
Reply #995 on:
May 26, 2015, 10:22:27 AM »
I have not finalized the top coat.
I have purchased the epoxy primer so I'll do this first and then worry about the topcoat. I would love to find some kind of paint that is ok for use under the waterline for a few days. While working on the Imron yesterday I was tempted to go back with that above the waterline. It has held up really well for the past 15 years.
Still on the fence though.
June 06, 2015, 02:51:01 PM
Reply #996
Reply #996 on:
June 06, 2015, 02:51:01 PM »
Washed the boat down early this morning along with the console. I planned on trying to prime the bottom today. They dried pretty quick and then it rained all of a sudden
So much for priming.
So I came back out a little while later and glued together a few pieces of epoxy lamination scraps I had together and then cut them into 2"Hx3"Wx 7/16"T "pads" that I mounted on the lower portion of the transom to mount my FF transducer so I'm not drilling into my new transom core.
I drilled a hole in the middle and lightly drilled into the transom skin and put a pretty short screw in to hold the 5min epoxy until it hardened. I scruffed up the area under each of the pads.
You can get the idea of the mounting here - and that is with the transducer about 1/4" proud of the bottom
I put one on each side in case I have to move it to the other side for some reason. I also mounted them in 10" from where the chine starts in case I need 9" tabs in the future.
I'll put the screws a little later today, mix up some thickened epoxy and fill the holes. Maybe tomorrow will be a priming day?
June 06, 2015, 05:00:09 PM
Reply #997
Reply #997 on:
June 06, 2015, 05:00:09 PM »
Nice touch with the pads
June 06, 2015, 05:48:54 PM
Reply #998
Reply #998 on:
June 06, 2015, 05:48:54 PM »
Thanks Craig.
I used a countersink bit and made the holes bigger and then dug out any resin left from the bit. I ground out enough around the pads and also cleaned them up with a 2" drill mounted round sandpaper (60 grit - Harbor Freight).
On this pic you can see the screw holes from where the transducer had been mounted.
I can never mix a tiny portion of epoxy - the measuring cups don't usually go into small enough increments. The pumps (and I have them) would have pumped too much also for this. I only needed about a quarter in size, maybe a half dollar size, to fill the holes and pack it in good. The smallest I could mix was 3 oz. then added cabosil and figured I would try a fillet to help secure them and also make it look better. I ended up with about half or more of what I mixed
I'll take a dowel tomorrow and wrap some sandpaper around it and smooth the fillets down a bit so the pads look like they were planned instead of last minute, like they were.
Hopefully the weather will leave me alone tomorrow,
June 07, 2015, 11:42:54 AM
Reply #999
Callyb
MidWest
Reply #999 on:
June 07, 2015, 11:42:54 AM »
Awesome work, as usual! I am looking forward to seeing her in primer (probably not as much as you though...
As far as paint, have you looked into the EMC paints at all? I'm not just bring it up because I bought it, especially since I haven't put any on yet... Just going off of the TDS, it seems to be a pretty awesome product.
Carl
___________________________
June 07, 2015, 12:17:03 PM
Reply #1000
larsli68
Reply #1000 on:
June 07, 2015, 12:17:03 PM »
Looking great Rick!
Great idea with the pads.
I hope the weather cooperates better soon. We have stormy weather here. It is supposed to last all week. I don't know what is up with the weather anymore...
//Lars
June 07, 2015, 01:07:07 PM
Reply #1001
Reply #1001 on:
June 07, 2015, 01:07:07 PM »
Thanks Carl and Lars.
I am ready to prime, have the air hose out and ready and the primer is stirred. Storms are popping up all around me so I don't know....
It'll take maybe 10 mins max to spray it but it needs to cure for at least an hour, I assume without rain getting to it
June 07, 2015, 03:07:19 PM
Reply #1002
Callyb
MidWest
Reply #1002 on:
June 07, 2015, 03:07:19 PM »
You might already be done, but I want you to know I am pulling for ya!
Carl
June 07, 2015, 03:43:04 PM
Reply #1003
Reply #1003 on:
June 07, 2015, 03:43:04 PM »
Thanks Carl
The pads came out well
The storms gave me a break and I was able to get the first coat of primer on
I wasn't happy with the way the HVLP gun was working, more pulsing instead of a steady spray. I played with everything and it seems that it wasn't going to work right. I'm using a 1.8 tip per paint mfr instructions. I put the 2.5 back on and tried it and it seems to spray better - I didn't notice this when I sprayed the gelcoat with Duratec. I'll have to do a little researching I guess before the next coat.
One thing for sure is I have a lot of pinholes to fill
June 07, 2015, 03:50:05 PM
Reply #1004
Callyb
MidWest
Reply #1004 on:
June 07, 2015, 03:50:05 PM »
Looks nice. I'm glad the weather cooperated with you. I'm sure you'll get the gun issue figured out before long. I'm working on my boat today too, hopefully I'll have some pics to post up later.
Carl
66
67
68
69
93
RickK's 170 rebuild
