It'll be interesting to see if the 2oz resin per sq ft for 1708 ballpark falls within your method's calculations.
What did you make the fairing compound from?
It is US Composites fairing blend. Honestly Quick fair is my prefered fairing compound because it sands so easy, but I have about half a bucket of this stuff, so why not use it up? I mean who doesn't like sanding?
So, some questions - do you pour the batch on top of all 3 layers and work it through or do it one layer at a time and stack it up? When done, do you lay all 3 layers on the area at once or peel it apart and lam them one at a time?
So is their blend a powder you mix with your resin?
Mucho clean! Do those sandpaper discs youre using have the plastic film on the back you peel off before sticking to the pad? Those little round pieces of plastic (folded in half) work great for dragging fairing compound over outside radii like you've got on the console. Kinda tricky but....
Carl,I had that exact same question a few weeks ago. The recommendation I got from Eugene Sun was to keep the trapezoid shape. I ended up making molds for the "extension caps" of my stringers (I am raising them about 3").Craig
