Express Fisherman/ Walkaround/ Explorer Rebuilds
Filler fuel line replacement
Topic: Filler fuel line replacement (Read 965 times)
July 14, 2016, 05:53:30 PM
Read 965 times
mischmerz
July 14, 2016, 05:53:30 PM »
More trouble. While I am waiting for a new gas tank I checked the filler and vent hoses. The fuel filler hose broke clean off with the wire harness rusted through. I now have to replace that hose but everything is foamed in the I can't even wiggle the hose. Is there any trick how to get the old fuel filler hose out there?
m.
July 14, 2016, 08:17:48 PM
Global Moderator
Re: Filler fuel line replacement
July 14, 2016, 08:17:48 PM »
When I get into the office in the AM I'll get you a couple three links on what other members went through and the results.
More to follow.
July 15, 2016, 07:20:18 AM
Global Moderator
July 15, 2016, 07:20:18 AM »
Something to mull over:
http://classicaquasport.com/smf/index.php?topic=11682.msg116052#msg116052
http://classicaquasport.com/smf/index.php?topic=9956.msg87432#msg87432
There are others in the "Fuel" forum that you may want to read through before you begin. As stated in one of the links, you really don't know what you may be up against until you start digging in. Some have tried using a come-a-long to pull the hose out while splicing the new section on to the old but for the most part, access and bends often reduce that method to luck, speaking of....
Good luck and post up a few pics of what you find and your work.
Thanks.
July 16, 2016, 08:45:25 PM
djbinding
84 200 XF , 08 Suzuki 115 DF
July 16, 2016, 08:45:25 PM »
Did my 200XF last year. I cut a hole inside and covered up with a deck plate. To remove foam and filler hose it takes lots of gouging with your hand and a flat bar. You can put an allen wrench on a drill and it will gouge out a lot. But u gonna have to use good old fashion elbow grease and a shop vac to remove enough foam until you can work out the old hose. My hose was cracked and leaking into the foam for who knows how long. The foam was saturated with gasoline. Once you're done you can refill the cavity with 2 part foam. The deck plate option was a lot easier than glassing over in my opinion.
Good luck
July 20, 2016, 08:11:21 PM
mischmerz
July 20, 2016, 08:11:21 PM »
Thanks for all the answers. I am still working to remove the old hose. And I have to admit - I find the lack of serviceability on those boats troubling. It would have been easy to run a conduit for those hoses as the manufacturer should have know that they will need to be replaced eventually.
m.
July 21, 2016, 07:55:22 AM
July 21, 2016, 07:55:22 AM »
Sad to say, the problem of access to important systems is getting worse as manufacturers have figured out that almost no one buys thinking about making future repairs. A new boat needs to be shiny on the showroom floor and have all the latest comfort features. Fuel tank hatches were the first casualty. Now you need 4 foot arms to even touch a bilge pump. It may be asking a bit much for a manufacturer to think about the needs of the second, third or ???? owner. The good news is, when you make the repair you'll be able to do it right.
August 11, 2016, 06:38:48 PM
mischmerz
August 11, 2016, 06:38:48 PM »
I am happy to report that the old fuel and vent lines are finally out. New tank will arrive next week currently installing a new thru the hull vent.
Michaela
August 11, 2016, 07:47:55 PM
August 11, 2016, 07:47:55 PM »
Nice progress!!
August 18, 2016, 07:28:12 PM
mischmerz
August 18, 2016, 07:28:12 PM »
Success. This was hard work indeed.
