Trailers
Trailer Make
Topic: Trailer Make (Read 661 times)
November 23, 2014, 05:35:15 PM
Read 661 times
Que Pasa
NorthEast
Trailer Make
November 23, 2014, 05:35:15 PM »
Can anyone Identify the make of this trailer.
November 23, 2014, 07:50:16 PM
Rigging Master
Re: Trailer Make
November 23, 2014, 07:50:16 PM »
It's a roller bunk trailer, could be anybodies. Why do you want to know? Need parts replacements? Go to etrailer or trailerpartssuperstore. I would assume there's no ID placard up by the tongue, port side...
November 23, 2014, 08:11:58 PM
Re: Trailer Make
November 23, 2014, 08:11:58 PM »
looks like it almost says "shorelandr" on the tube
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
1989 Fountain 12-meter
SOLD
1992 Talon F-20
SOLD
November 23, 2014, 08:23:23 PM
Que Pasa
NorthEast
Re: Trailer Make
November 23, 2014, 08:23:23 PM »
Sea bob, no Id and yes, need to extend the tongue and no keel roller.
Aswaff, I see the S and that's what I was thinking
November 23, 2014, 08:38:55 PM
Que Pasa
NorthEast
Re: Trailer Make
November 23, 2014, 08:38:55 PM »
Sea Lion maybe?
November 23, 2014, 08:47:19 PM
Rigging Master
Re: Trailer Make
November 23, 2014, 08:47:19 PM »
More likely Sea Lion, I believe they are a Jersey builder...
November 29, 2014, 09:35:25 AM
HeavyDinSC
Re: Trailer Make
November 29, 2014, 09:35:25 AM »
Frame style and roller arms look just like those on my trailer (for a 170), which is a Shoreline trailer. (Evidently, Shoreline shut down in the late '80s or early '90s.) I've slowly been rebuilding my trailer and haven't worried about matching parts from the same manufacturer. As long as you've got the dimensions measured correctly, and the materials you're using can sustain the same loads as the parts you're replacing, you should be fine.
Example: I took off the rusting galvanized crossbeams and replaced them with aluminum ones. I used the same hanging brackets to attach the new crossbeams to the frame, but I first coated the brackets with a rust preventer and then applied metal paint. Also moved from roller arms to bunks (doubled 2 X 8s capped with a plastic 1 x 4). I'm one month into using the new set up and so far so good.
November 29, 2014, 01:21:24 PM
Mechanical Master
Re: Trailer Make
November 29, 2014, 01:21:24 PM »
This may seem obvious, but do you have a title/bill of sale/VIN? Any of those must list the manufacturer.
November 30, 2014, 06:39:16 PM
Que Pasa
NorthEast
Re: Trailer Make
November 30, 2014, 06:39:16 PM »
Well, I was buying the boat on the trailer. Long story short, it's a load rite, and I am the proud new owner of a 76 22-2. Will be calling load rite tomorrow for capacity specs. :pirat:
November 30, 2014, 06:51:36 PM
dburr
Re: Trailer Make
Reply #9 on:
November 30, 2014, 06:51:36 PM »
Lucky.... Mine said YachtClub on the side of the tube, yet no VIN, no builders plate, and, luckily enough is was sold as "home built" and now it has a title....
Every state is different on the trailer registration laws...
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
November 30, 2014, 09:53:30 PM
Que Pasa
NorthEast
Re: Trailer Make
Reply #10 on:
November 30, 2014, 09:53:30 PM »
D burr, yea the guy I bought from had the title. Lotta work ahead with the 22, as I see a patch on the bottom of the hull. In the fuel tank area. But got lucky as the floor has no soft spots.
Trailers
Trailer Make
