222 CCP Rebuilds
1984 222 CCP
8
9
Topic: 1984 222 CCP (Read 18398 times)
January 07, 2013, 07:48:52 PM
Reply #90
gman 82 aquasport
Re: 1984 222 CCP
Reply #90 on:
January 07, 2013, 07:48:52 PM »
Honda looks good hanging out back there
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
January 07, 2013, 08:47:55 PM
Reply #91
fabuck71
Re: 1984 222 CCP
Reply #91 on:
January 07, 2013, 08:47:55 PM »
I researched the data sheets on the Honda marine website and talked to Tony. With the new @ weight of the boat around only 1800 lbs and Porta bracket we think top speed around 42-45 mph.
Alex Buck
Bass Underwriters of Florida
800.528.5386
January 07, 2013, 10:23:10 PM
Reply #92
gman 82 aquasport
Re: 1984 222 CCP
Reply #92 on:
January 07, 2013, 10:23:10 PM »
Sounds like a winner 8)
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
January 27, 2013, 05:49:13 PM
Reply #93
Re: 1984 222 CCP
Reply #93 on:
January 27, 2013, 05:49:13 PM »
On page 3, on one of the photos of the transom bait station, where is met the existing transom cap, it looks like you faired it with a blue putty. What do you use to fair fiberglass before paint or gelcoat that is easy to fill and sand? it does not have to be structural as the work underneath is will be strong enough, but it has to be strong enough to hold up to typical surface use and marine conditions.
February 06, 2013, 12:46:11 PM
Reply #94
fabuck71
Re: 1984 222 CCP
Reply #94 on:
February 06, 2013, 12:46:11 PM »
Koz, I'll ask about that. I'm pretty sure it is an epoxy/filler mixture. I picked up the boat from Abels Marine today. I think they did a great job and worked well with me. Towed her straight to SeaForce to finish painting and final touches. Check it out and let me know what you think.
All the teak will be removed and refinished. Tony at Abels put the Porta Bracket switch right next to the trim switch. Looks good huh?
The gauges will be covered with Plexi
Porta Bracket Unit
I know Bob will be happy
I can't wait to give her the maiden voyage. This is my first Brand New Motor ever and pretty much a brand new boat!
Alex Buck
800.528.5386
February 10, 2013, 07:34:09 PM
Reply #95
fishinonthebrain
Re: 1984 222 CCP
Reply #95 on:
February 10, 2013, 07:34:09 PM »
Looking sweet wish I was as far along as you.
1987 222CCP current rebuild.
March 16, 2013, 10:38:53 AM
Reply #96
fishinonthebrain
Re: 1984 222 CCP
Reply #96 on:
March 16, 2013, 10:38:53 AM »
Had they finished painting that baby up yet? I need some more boat porn!
March 16, 2013, 11:23:56 PM
Reply #97
dburr
Re: 1984 222 CCP
Reply #97 on:
March 16, 2013, 11:23:56 PM »
It's late..
I am sitting here looking at the top of the bracket mount and wondering why does it extend all the way to the cap and why paint it black?!?!?
Then I realize I am looking at the refection of the top plate of the bracket in the beautiful finnish of the transom
.. That is SOME paint job!!!
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
April 24, 2013, 04:06:28 PM
Reply #98
fabuck71
Re: 1984 222 CCP
Reply #98 on:
April 24, 2013, 04:06:28 PM »
Sorry it's been a while, just slammed which is a good thing. Thanks so much to Bob, Eddie and Crew all the hard work. Getting ready for non-skid
Rubrail complete, Bottom complete and non-skid complete.
Saturday is the delivery day
Alex Buck
800.528.5386
April 24, 2013, 04:10:15 PM
Reply #99
Mechanical Master
Re: 1984 222 CCP
Reply #99 on:
April 24, 2013, 04:10:15 PM »
Look great Alex!
Time for a splash!
April 24, 2013, 04:35:29 PM
Reply #100
fabuck71
Re: 1984 222 CCP
Reply #100 on:
April 24, 2013, 04:35:29 PM »
Thanks Captain, you are telling me. I'm ready!
Alex Buck
800.528.5386
April 25, 2013, 09:06:26 AM
Reply #101
jdupree
Re: 1984 222 CCP
Reply #101 on:
April 25, 2013, 09:06:26 AM »
Wow
What a beauty :!: Looks great Alex
John L. Dupree, III
AQABLA84E999
Member #257
April 27, 2013, 09:59:57 PM
Reply #102
fishinonthebrain
Re: 1984 222 CCP
Reply #102 on:
April 27, 2013, 09:59:57 PM »
Came together nice. Now go fishing!
May 03, 2013, 10:25:53 PM
Reply #103
fabuck71
Re: 1984 222 CCP
Reply #103 on:
May 03, 2013, 10:25:53 PM »
How do I mount the leanpost into this nidacore floor? Thanks
Alex Buck
800.528.5386
May 03, 2013, 11:12:58 PM
Reply #104
Purgatory
Re: 1984 222 CCP
Reply #104 on:
May 03, 2013, 11:12:58 PM »
Alex, congrats, know you're excited
Regarding mounting the leaning post...did they make any provisions in the build ...an underneath layer or imbedded layer of duralloy or other synthetic high density material that can be screwed to? How and what is the console mounted to?
If that was not in the build...you may need to through-bolt through the nida with large backing washers at a minimum and locknuts. Hopefully you can get to this area through the tank inspection deckplate.
It all depends on the width of your leaning post base. Does it fall within the confines of the tank hatch width, or does it go out a little farther and land on the stringer tops? If it does land on the stringers...you can screw through the nida to the glass on the stringer tops on each end and 4200 the rest of the plate. If it doesn't hit on top of the stringers and you can't get to it through the deck inspection...you may need to pull the tank hatch and install it while lifted. My deck is cored with nida, and though it is light and doesn't rot....the downside is it doesn't hold screws.
My rebuild has been a series of mini-adventures like this.
No worries...let us know what you're looking at.
8
9
222 CCP Rebuilds
1984 222 CCP
