I assume it is hydraulic steering?
Does it "chatter" when you turn the wheel.....that is, can you feel a clicking through the wheel?
how much does it cost to fix that corroded steering tube? Mine is shot 94 yamaha 150ss
Quote from: "bumpster"how much does it cost to fix that corroded steering tube? Mine is shot 94 yamaha 150ssRob,The best thing to do is take off the end caps and take out the seals, remove the cylinder, take it to a hyd shop, have them grind/smooth all the nicks/dings out, get rid of the rust, then re-plate, sorta like trim cylinders on an outdrive...
