UPDATE:I went out to the boat and lowered the motor from trailering bracket so I could turn it back and forth to try and troubleshoot the problem. Surprisingly, the motor turned smoothly with little effort. I think the problem almost had to be a kinked line that's fine now. Too freakin' weird!
not to piggy back the thread, but i am having similar issues. Mine (cable, not hydraulic) turns great with one finger at the dock, but under load and even WOT on perfect plane, it takes two hands and alot of effort to steer. Tilt tube issues here? need to be replaced or just cleaned? Or is it the bushings or something else further down the exhaust shaft where the motor attaches to the steering arm near the lowerunit? Thanks
Quote from: "allen456"not to piggy back the thread, but i am having similar issues. Mine (cable, not hydraulic) turns great with one finger at the dock, but under load and even WOT on perfect plane, it takes two hands and alot of effort to steer. Tilt tube issues here? need to be replaced or just cleaned? Or is it the bushings or something else further down the exhaust shaft where the motor attaches to the steering arm near the lowerunit? ThanksAllen,How old is the system? Original? 10 years old? When was the last time you pulled the rod out of the tilt tube and lubed it? Also, what ius the orientation of your torque tab below your cav plate? Should be about 1:00, looking from underneath...
Quote from: "cdoyal"UPDATE:I went out to the boat and lowered the motor from trailering bracket so I could turn it back and forth to try and troubleshoot the problem. Surprisingly, the motor turned smoothly with little effort. I think the problem almost had to be a kinked line that's fine now. Too freakin' weird!CD,If you indeed had a kinked line, then you need to replace it...PRONTO! That kink will create a very weak spot in the hose, and it can blow out on you quicker than ! Not to be the bearer of bad news, but any time I have encountered a kinked hyd hose, well, it get's replaced. 1000 PSI will rupture that in a heartbeat...
Does it "chatter" when you turn the wheel.....that is, can you feel a clicking through the wheel?
Most likely both. Buy the minimal amount of hydraulic fluid ( a pint would be a plenty, but you usually only find it in quarts) add it slowly as you continue to turn the wheel several times from port to starboard, leaving the helm cap off. You'll feel it getting smoother as you continue to add. It won't take much, most likely only a few ounces. Top it off 'till it nearly overflows onto the console. Continue to spin the wheel/bleed the air. Leave whats left over in the boat.Thats it....go fishin'.
Does it have to be marine grade fluid? $20/quart seems a bit steep!
Quote from: "cdoyal"Does it have to be marine grade fluid? $20/quart seems a bit steep!Well, I'll try once more.The link in post ten will do several things.1. It will answer your question on alternate fluids you can use.2. Proper bleeding techniques and why they work.3. Internal diagrams will help to understand how the system works.The steering system is an important part of any boat and you showed concern in your first post about yours. 20 bucks a quart really doesn't sound bad when you compare it to the overall cost and importance of the system.Good Luck
