Author Topic: 1968 Aquasport Flatback Diver - Shipoke Rebuild for Hefner  (Read 19377 times)
February 01, 2013, 04:53:44 PM
Reply #120
ashley
Re: 1968 Aquasport Flatback Diver - Shipoke Rebuild for Hefn
« Reply #120 on: February 01, 2013, 04:53:44 PM »
Quote from: "Capt Matt"
Interested to see if you opt for the keel extention
Capt Matt
What do you think Capt. Matt?
February 01, 2013, 05:36:20 PM
Reply #121
CaptSteveBetz
    • http://www.flatsandbay.com/.
« Reply #121 on: February 01, 2013, 05:36:20 PM »
Quote from: "ashley"
Capt Matt
I am not Capt. Matt but I can tell you from experience that if you have ever been in a flat back,fully trimmed up and running close to WOT and done a 180 you would opt for the keel extension.
I have been and it is not a fun ride. Even with my keel extended on my PL 24 flat back my boat slides and if I am not careful will swap ends.
It will only help the performance when turning.
Capt. Steve Betz
Tampa Flats and Bay Charters
www.flatsandbay.com
813-727-8843
February 01, 2013, 06:47:36 PM
Reply #122
« Reply #122 on: February 01, 2013, 06:47:36 PM »
Quote from: "CaptSteveBetz"
Capt Matt
Capt Betz/Capt Matt/anyone else with flatback experience:
What are your thoughts on adding the bait boxes to the transom on these flatbacks?  Similar to the ones Scott put on the Miss Delmarva (except for a flatback).  I was wondering if you thought they would "bite" on a turn and give a little more control/traction.
February 06, 2013, 07:59:10 PM
Reply #123
ashley
« Reply #123 on: February 06, 2013, 07:59:10 PM »
fairing continues.....
February 06, 2013, 08:05:08 PM
Reply #124
gman 82 aquasport
« Reply #124 on: February 06, 2013, 08:05:08 PM »
I don't have a flat back but I do see where the hull would have a tendency to "slide" in a sharp power turn as apposed to having a little bite back there with a keel extension...I guess the million $ question will be your usage of the boat...on slick water will a little slide action be OK or would it not feel right :scratch:
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 06, 2013, 08:43:31 PM
Reply #125
ashley
« Reply #125 on: February 06, 2013, 08:43:31 PM »
Quote from: "gman 82 aquasport"
I think I'm going to leave the keel alone. The way I understand it is that with the original set up you don't need a keel extension. Boats with porta brackets have extra length and the keel should be extented.?? Anyone with a flatback with original keel out there??
February 06, 2013, 08:47:44 PM
Reply #126
« Reply #126 on: February 06, 2013, 08:47:44 PM »
Nice work you guys.
Regarding the potential keel. Since she's flipped....now is the time to make that decision.
Will give Matt a call.... hang loose for just a bit.
February 07, 2013, 04:32:53 PM
Reply #127
« Reply #127 on: February 07, 2013, 04:32:53 PM »
Nice work you guys.
Matt says without question install the extended keel.
February 07, 2013, 05:06:50 PM
Reply #128
ashley
« Reply #128 on: February 07, 2013, 05:06:50 PM »
Nice work you guys.
Thanks man. Keel will be extended.
February 07, 2013, 10:03:04 PM
Reply #129
« Reply #129 on: February 07, 2013, 10:03:04 PM »
Capt Matt
 Matt states exactly the same as Steve. The extended keel is a big plus. Minimizes sliding in narrow creeks. Particularly helpful turning in slick water.
February 08, 2013, 07:52:40 PM
Reply #130
ashley
« Reply #130 on: February 08, 2013, 07:52:40 PM »
Eugene's got the keel extended and fairing continues.
February 08, 2013, 08:03:47 PM
Reply #131
« Reply #131 on: February 08, 2013, 08:03:47 PM »
That Eugene is quick!  Any details on what materials were used?  And any science behind stopping it at that point?  I'll be doing the same thing to mine eventually.
February 08, 2013, 08:10:22 PM
Reply #132
« Reply #132 on: February 08, 2013, 08:10:22 PM »
That is damn clean job.
A lot more to it than appears.
Sweet work guys :salut:
February 08, 2013, 08:53:20 PM
Reply #133
« Reply #133 on: February 08, 2013, 08:53:20 PM »
i will also be extending my keel when that point comes.
February 09, 2013, 09:02:59 AM
Reply #134
ashley
« Reply #134 on: February 09, 2013, 09:02:59 AM »
Quote from: "CLM65"
The core material was Penski board. Not sure about length yet?
