Author Topic: Fuel tank. (Tampa)  (Read 765 times)
November 12, 2012, 08:06:49 PM
Read 765 times
Danew20
Fuel tank. (Tampa)
« on: November 12, 2012, 08:06:49 PM »
Any one know of a good place to have a fuel tank made or any place to buy one. Looking for a 60-70 gallon, plastic or aluminum.  Want one that will fit in the original tank cavity.
What's everyone else gone with?
November 12, 2012, 08:19:36 PM
Re: Fuel tank. (Tampa)
« Reply #1 on: November 12, 2012, 08:19:36 PM »
November 12, 2012, 08:28:33 PM
« Reply #2 on: November 12, 2012, 08:28:33 PM »
3 hrs. north of Tampa.
http://www.rdsaluminum.com/
Built factory Aqua tanks for years.
I currently run one.
November 12, 2012, 08:40:50 PM
« Reply #3 on: November 12, 2012, 08:40:50 PM »
moeller has a ton of fuel tanks that may fit... found a shallow 72 gallon tank that will fit in my flat back...
http://www.moellermarine.com/oem/fuel_tanks/
November 12, 2012, 11:05:35 PM
« Reply #4 on: November 12, 2012, 11:05:35 PM »
Quote from: "Danew20"
Depends on your preference, aluminum or poly. Pluses and minuses for both.
For aluminum tanks, a trusted supplier has served many members for years:
viewtopic.php?f=12&t=9353
A commercial manufacturer must issue a build certificate/placard conforming to testing standards. Beware the backyard builder.
Of course the question is cost. For a quality aluminum tank....figure $9 to 10 per gallon. Fifty gallons....$450 plus delivery.
Per example: my 82 gallon aluminum tank from Alloy Metal Works (link above) was $740.00.
Research, do your due diligence...and shop around.
November 13, 2012, 12:02:06 PM
Georgie
« Reply #5 on: November 13, 2012, 12:02:06 PM »
Had a gorgeous custom replacement for my father's 1979 170 made by a welder right down the street from me.  AIM Aluminum Alloy Welding in Fort Lauderdale.  Total cost was approximately $350 with WEMA sender and they moved the locations of the fill and vent pipes so I could cut the ugly old ends off the stock hoses.   100% recommendation.  Took them just over a week.  They apparently do all the aluminum work for a boat and motor sales/parts/repair shop right across the street too, so they know marine applications.
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
November 13, 2012, 12:18:35 PM
« Reply #6 on: November 13, 2012, 12:18:35 PM »
If you don't mind a little road trip, The Marine Connection in Ft. Pierce has tons of tanks in the racks in their warehouse, you just need to know the dimensions, they have a set price "per gallon" I think it is 3.00 for water tanks, and 5 or 6 for fuel, but you could call them ask.. great place to visit also, like Disney World for boaters
November 13, 2012, 02:17:03 PM
« Reply #7 on: November 13, 2012, 02:17:03 PM »
That's a DAMN good suggestion right there!  Might even run into Pete! :shock:  :shock:
November 13, 2012, 03:13:55 PM
« Reply #8 on: November 13, 2012, 03:13:55 PM »
Mention you are a CAS member, with a purchase over $100 you get a free AS decal.
