One thing that puzzles me. I was hanging and rigging and an absolute ton of OMCs in the time frame of Rick's motor. The trim plug was always a triangular 3-pin Deutsch. Never saw a round one. Older OMCs, say circa early 80s? Yep...
SB I was wrong - my T&T connector is a triangular Deutsch. I corrected my statement above. I'll take some pics as I go through this.
Hi Rick,As I mentioned earlier; the difference between the two engines will be the port size. Once you get the exhaust baffle plate off between the cylinder banks you can measure the exhaust port diameter and then you will know what you have. The task will be to find out what the port size is supposed to be between the two engines but a reputable engine builder or OMC guru will know. There may also be suttle differences in combustion chamber size or geometry in the cylinder heads that may give you a clue. In reality, the parts to rebuild the 90 or 115 are probably indentical assuming the bore diameters are the same.
