the fuel and vent lines are foamed in. I started cutting away foam from behind the pie plate near the fuel fill. I think this will be the trickiest part, any hints about how to get the lines free would be appreciated.
I'm going through the same process that alandry is with the tank on my 1986 Aquasport 170. Mine looked similar when I exhumed it, but I did have a bunch of pin sized holes (and a few larger) from corrosion. Before I get the new tank installed, I'm thinking about adding a one-way drain plug at the aft end of the tank basin (what he calls the coffin) so that water can exit, but not enter. Any thoughts on this solution?
