Author Topic: In the Garage  (Read 617 times)
October 30, 2012, 08:10:27 PM
Read 617 times
alandry100
In the Garage
« on: October 30, 2012, 08:10:27 PM »
Got the boat in the garage before the storm. Could not get the trailer in the garage so built a pair of carriages - a bit of an adventure getting it in. If anyone sees anything that could be adjusted - I would appreciate it. It will stay in there for the winter, plan to replace the fuel tank.
79\' 170
2005 Yamaha 70 two stroke
October 30, 2012, 09:06:43 PM
Re: In the Garage
« Reply #1 on: October 30, 2012, 09:06:43 PM »
Not that she'll really go anywhere...but wheel chocks?
October 30, 2012, 09:20:46 PM
Re: In the Garage
« Reply #2 on: October 30, 2012, 09:20:46 PM »
Good job, she's planted as planned :thumright: Throw on some chocks as Bob suggests, you're good :thumright:
November 01, 2012, 12:11:14 AM
dburr
Re: In the Garage
« Reply #3 on: November 01, 2012, 12:11:14 AM »
What is keeping the vertical timbers under the stern from spreading apart? :scratch:
Gonna be nice having her inside, tight fit ain't it? :mrgreen:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
November 03, 2012, 08:52:37 AM
alandry100
Re: In the Garage
« Reply #4 on: November 03, 2012, 08:52:37 AM »
Very tight fit and yes it will be very nice  - I am going to start the tank removal soon - will post progress and seek assistance probably.
There are 45 degree braces from the 2x10ish to the 2x4. You can see it poking out from under the blanket. I noticed that the blanket moved a bit on the opposite side where most of the pressure is. Do you think this will create a stress problem on the hull.?
79\' 170
November 03, 2012, 10:18:15 AM
dburr
Re: In the Garage
« Reply #5 on: November 03, 2012, 10:18:15 AM »
Think of the weight of the hull translating throught the blanket to the corner.. It will be high point stress, but to high? I don't know...
I am such a whack job that I would scribe the hull shape on the cradle, then whack the bevel off with enough allowance to get a 2x6 in there to spread the load ..
Maybe some blocks under the chines might be easier...
Lots of options..
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
