Interesting method Rick! There are so many ways to do non-skid & many of them come out very well!Jdupree,Yes, the mat on top of the 1708 has given my deck surface high & low spots that act as a kind of smooth anti-skid or grip surface. The bumpy & smooth surface is still too slick when wet, so that's why I want to lay down some non-skid. That is a good method to level out the deck. I guess that was mainly my question. Whether to level out the surface with kiwigrip or if I was going to need to fair out or lay a new layer of fiberglass on the whole deck before applying. I will stay away from durabak.I want the finished look that non-skid gives a boat because my boat was so well done in the rebuild, but it looks like the deck was an afterthought.How much should I order to cover the decks on a 22-2? Also, would yall stick to just applying non-skid on the deck & casting deck, or would you also apply it to your cap? They say a gallon covers 80 sq. Ft.Thanks!Ben
I really like my kiwi grip, I went with light grey. It does get dirty pretty easy though and needs to be scrubbed with soap and water to be cleaned. It is the best non skid even with fish slime all over the deck you never slip.I have chipped it a few times with a anchor etc but being a water based paint touch up is a breeze. The main thing when putting it down is the surface is clean, it will cover lots of imperfections and can be put down as thick as needed. I used 3 gallons but that was for the top of the gunnels, transom and I also painted the inside of my transom cabinet and console with it. I would go with 2 gallons if you are just doing the deck and put it on thick. Be sure to get a few extra rollers when you order.Good luck with itCapt Matt
