Author Topic: 1986 222 osprey  (Read 9369 times)
November 21, 2012, 01:29:48 PM
Reply #30
Danew20
Re: 1986 222 osprey
« Reply #30 on: November 21, 2012, 01:29:48 PM »
Yes, many years of fishing out of smaller boats I know exactly what I want to maximize all the space of the 22.
I would not put any batteries close to the tank and if they went below deck it would be way forward for tm batteries and be boxed in for security.
I am using the stock console but doing mods to try and make toe kicks and rod storage so it does not take added space in the walkways, and add more of a face for electronics and such. I have already cut the well out of the front and plan to put batteries and switch there for easy access.
Thanks for the replies and input.
Weight distribution is a pain to try and plan for so we may get it wet a few times before bolting everything down. I can't even cut the scuppers until I see how she sits.
November 23, 2012, 06:13:17 PM
Reply #31
Danew20
Re: 1986 222 osprey
« Reply #31 on: November 23, 2012, 06:13:17 PM »
Molded stringers back in. Need to grind then clean and size the drains once its dried then install the knees soon.
November 24, 2012, 12:11:10 PM
Reply #32
orb
Re: 1986 222 osprey
« Reply #32 on: November 24, 2012, 12:11:10 PM »
It looks great. I can't wait to see the finished product. Keep the pictures coming.
70\'s  240 seahunter(rebuilding now)
Photogallery-
http://www.classicaquasport.com/gallery ... &protype=1
\'77 22-2 (rebuild on hold)
1997 19\' sundance 70 merc
November 24, 2012, 05:42:39 PM
Reply #33
Re: 1986 222 osprey
« Reply #33 on: November 24, 2012, 05:42:39 PM »
D20, sent you a PM
November 25, 2012, 12:20:53 AM
Reply #34
Danew20
Re: 1986 222 osprey
« Reply #34 on: November 25, 2012, 12:20:53 AM »
Knees....
Hope to glass tomorrow if the weather stays warm enough for the resin to take.
November 25, 2012, 07:47:28 PM
Reply #35
Danew20
Re: 1986 222 osprey
« Reply #35 on: November 25, 2012, 07:47:28 PM »
December 18, 2012, 07:32:38 PM
Reply #36
Danew20
Re: 1986 222 osprey
« Reply #36 on: December 18, 2012, 07:32:38 PM »
Knees in...
Fixing/finishing the floor and getting the tank made soon.
December 18, 2012, 08:57:17 PM
Reply #37
Re: 1986 222 osprey
« Reply #37 on: December 18, 2012, 08:57:17 PM »
:thumleft:
December 18, 2012, 09:14:45 PM
Reply #38
Re: 1986 222 osprey
« Reply #38 on: December 18, 2012, 09:14:45 PM »
Like the curvature on the lam. Good work.
December 20, 2012, 08:03:22 AM
Reply #39
gman 82 aquasport
Re: 1986 222 osprey
« Reply #39 on: December 20, 2012, 08:03:22 AM »
Knees look good..she's coming along nicely..have you decided yet if you will use a smaller tank or go back with original size? :)
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
December 21, 2012, 07:45:46 PM
Reply #40
Danew20
Re: 1986 222 osprey
« Reply #40 on: December 21, 2012, 07:45:46 PM »
Put a thru-pipe in the stringer for wires and plumbing, and filled the rest of the stringer with foam.
Also pulled some plugs and cut into the floor and found a good bit of wet wood. Just seems to be around the console, the rear portion is dry. May just cut out the rot and repair, but then again why not replace it all, will just be more time and expense.
December 21, 2012, 07:47:24 PM
Reply #41
Danew20
Re: 1986 222 osprey
« Reply #41 on: December 21, 2012, 07:47:24 PM »
Going to go with a bit smaller tank, should have good enough range with 60 gal with engines these days. Plus it will open more room in the rear for a hatch.
December 26, 2012, 09:59:22 PM
Reply #42
Danew20
Re: 1986 222 osprey
« Reply #42 on: December 26, 2012, 09:59:22 PM »
Tore up the floor...
Removed the foam and cleaned up.,,,
Cut out the deck to expose and use so much more room...
Layout for new bulkheads for the tank....
December 27, 2012, 06:20:32 AM
Reply #43
Re: 1986 222 osprey
« Reply #43 on: December 27, 2012, 06:20:32 AM »
Stringers look to be in good shape.
December 27, 2012, 06:38:33 AM
Reply #44
Re: 1986 222 osprey
« Reply #44 on: December 27, 2012, 06:38:33 AM »
Quote from: "Danew20"
Interesting,
Looks like the stringers were notched to allow for the fuel fill from either side. Not sure why early models filled from the starboard side and the typical vehicle fill was on the driver side creating a PITA to fill the tow vehicle and the boat. Now's your chance to remedy that situation if it wasn't already that way.
