Hard to tell but I'd say the black thing is some sort of a transducer.
Quote from: "wingtime"Hard to tell but I'd say the black thing is some sort of a transducer.Shoot thru hull type but older design is what I was thinking.
Quote from: "Capt. Bob"Quote from: "wingtime"Hard to tell but I'd say the black thing is some sort of a transducer.Shoot thru hull type but older design is what I was thinking.Would it be best to leave it as is oooor maybe remove it all together you think? C
So had a good look...damn, that looks like an old Mako bilge!!! Mako loved to use those red handles plastic fittings...Question Chris. Is that lower valve attached to the thru hull intake? If so, you need to get rid of that and install a proper bronze or marelon shut-off valve. And that sure doesn't look like marelon, which is the only approved below the waterline non-metallic material...
That is definitely an old shoot-through, see where the cable goes into the potting compound. Myself? Get a pry bar under there and get rid of it. It's not doing anything, so if you tear it up in the process, no loss. One less piece of clutter in the bilge...Now need to look at the rest of the pics...
Chris,We used Shurflos at Proline, both Blasters and Bait Masters. You'll read a lot, especially on THT, about pump longevity. Well, that applies to all brands, not just Shurflo. Jabsco, Flo-Jet, whatever. The key is to install the pump in the driest area possible. Use heat shrink adhesive lined butts for the terminations. Even spray the pump with anti-corrosion spray yearly. The pump housings don't like moisture (they rust), even though the instructions will say that they can tolerate damp environments.I have an 8 year old Blaster in the shop, looks like hell...but still runs like a champ!P.S. Look for a box today...
