Author Topic: 1968 22-2 FB rebuild  (Read 37123 times)
July 15, 2015, 10:50:08 PM
Reply #465
Re: 1968 22-2 FB rebuild
« Reply #465 on: July 15, 2015, 10:50:08 PM »
Yeah, I was off by a mile too.  That is a sweet looking trailer...I'm going to need one eventually too.
July 16, 2015, 06:11:12 PM
Reply #466
« Reply #466 on: July 16, 2015, 06:11:12 PM »
the pics dont do it justice! for a size reference, its 9ft wide outside to outside(yes 9 feet!) of the fenders, 86 inches between fenders, and 28 feet from the end of the bunk to the hitch. the I-beam sits 11 inches off the ground
note the adjustable center bunks instead of the wood V-blocks that are usually standard on Owens' trailers. Jeff is trying something new with the adjustable center bunks for my hull because of the keel on the flat backs. he said a couple that he's done wear prematurely on the V pad and inside edge of the center bunks. i use my trailer quite a bit so if it works as planned i'll report back and he's gonna do the flat backs that way from now on...
July 16, 2015, 06:52:21 PM
Reply #467
« Reply #467 on: July 16, 2015, 06:52:21 PM »
I added those adjustable bunks to my trailer to help stabilize the hull before I added cloth everywhere on the inside of the bare hull.  Glad I did.
July 20, 2015, 03:36:00 PM
Reply #468
« Reply #468 on: July 20, 2015, 03:36:00 PM »
put the boat on the trailer, ended up taking it back to Owens for some bunk adjustment. the fwd end of the main bunks need to be raised and the center bunks hit my thru-hull on the stbd side.  pulled great though! super smooth ride. and loaded so much easier than my old trailer. and 2 months in the water, other than Algae on the trim tabs, not a speck of growth on the bottom!
July 20, 2015, 05:50:43 PM
Reply #469
« Reply #469 on: July 20, 2015, 05:50:43 PM »
picked it back up from Owens after some minor adjustments. Fits like a glove now!
July 20, 2015, 07:01:17 PM
Reply #470
« Reply #470 on: July 20, 2015, 07:01:17 PM »
Nice looking setup there Aaron!  Can't tell from the pics...torsion axles or springs?
July 20, 2015, 07:40:00 PM
Reply #471
« Reply #471 on: July 20, 2015, 07:40:00 PM »
torsion drop axles, only way to get the frame that low. you can see how low the frame sits.
here you can see exactly how much drop the axles have.
couple more pics of exactly how the trailer is set up, and the bottom pretty clean for being in the water for over 2 months
July 20, 2015, 07:56:10 PM
Reply #472
« Reply #472 on: July 20, 2015, 07:56:10 PM »
That's pretty low - should be real easy to launch in shallow water.
July 20, 2015, 09:34:29 PM
Reply #473
« Reply #473 on: July 20, 2015, 09:34:29 PM »
Sure is low - those armadillos don't have a chance!  Awesome trailer, Aaron :great02:.
July 21, 2015, 04:13:41 PM
Reply #474
« Reply #474 on: July 21, 2015, 04:13:41 PM »
finally installed some electronics. mounted the largest Garmin that would fit, the 840xs. Also got Garmin's GFS10 fuel flow sensor. Automatically calculates fuel mileage/consumption
July 21, 2015, 06:37:59 PM
Reply #475
« Reply #475 on: July 21, 2015, 06:37:59 PM »
NICE!!!  What are you going to do for Christmas now :think:
July 21, 2015, 07:09:09 PM
Reply #476
« Reply #476 on: July 21, 2015, 07:09:09 PM »
theres always a 2nd display, I-pilot trolling motor, blade power-pole, new 4-stroke merc, and a whole other list for the truck!
July 26, 2015, 04:13:02 PM
Reply #477
« Reply #477 on: July 26, 2015, 04:13:02 PM »
installed my Fusion ip600 radio from the Contender and 6-1/2 inch speakers yesterday, and today i installed the transducer for the FF/GPS, and i wasnt happy with the lights on the trailer, which i told Jeff Owens I'll change.... the 4 speakers are all mounted on the console, 2 facing fwd, 2 facing aft. with the console being almost like a sealed enclosure, it had real deep and great sounding bass. almost as if there was a powered sub on board.
swapped the marker lights out for LED's that i had
July 26, 2015, 07:07:37 PM
Reply #478
« Reply #478 on: July 26, 2015, 07:07:37 PM »
The console is filling up nicely (huge display on the MFD) :thumleft:
The trailer looks like it'll last a long time.
August 12, 2015, 09:41:48 PM
Reply #479
« Reply #479 on: August 12, 2015, 09:41:48 PM »
had some cushions made for the casting deck.
and i dont know if i posted the pics here, took the boat up to the suwannee river on 7/28
who wants to add these to their fleet?
where the Santa Fe River spills into the Suwannee River.
sittin pretty
another project anyone?
US129 bridge over santa fe
another bridge on the suwannee
loaded back up. this trailer loaded SO much easier than my old trailer, and with the torsion axles, it pulls so much smoother, definitely happy about it.
